190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
sequence of operation of aux cooling fan
Old 01-25-2009, 01:20 PM
anderbud's Avatar
1986 190e
i have a 1986 190e 2.3 the aux cooling fan runs when jumpered to the battery.
what is the sequence of operation of the aux cooling fan. Does it only run when a/c is on
Old 01-29-2009, 01:41 AM
Runninrebel211's Avatar
1993 190E 2.6
Im not sure for a 2.3 but for my 2.6 it turns on only when the A/C compressor has been turned on for some time. The other time it will turn on is when the engine is about to over heat. Sometimes it turns on instantly when the A/C is turned on in hot weather such as Las Vegas heat in 120 degrees.
Old 08-31-2016, 11:45 AM
Mdhgc1967's Avatar
91 190e. 2011 sl55
I'm having having a similar problem, but the fans don't run when the switch on the receiver dryer is jumped.
Quick Reply: sequence of operation of aux cooling fan
