Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > 190E (W201)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-14-2010, 05:10 PM   #1
Drives: 1991 MB 190 E 2.3
Coolant leak - front of engine
Greetings MBWorld 190 fans...
My 2.3E 190 with 205K is starting to drop coolant when the engine is running. From what I can see it drips from approximately the right front passenger side of the engine and drips onto the plastic skid pan.
All the hoses on top of the engine are really tight and dry.
It really must be pouring out when on the road as I have to refill the resivor tank about every 5th trip. When I change the oil next weekend Im also going to tighten some of the hoses coming out of the block below the main flywheel but the drip looks to be coming out around this location.
I think I replaced the water pump about 100K ago but it may be the original unit.
Any steer from MB 190 members would be welcome......
To remove this ad, register today or login if you already are registered!
Rauhbatz is offline   Reply With Quote
Tags
16v, 190, 190d, 190e, 23, bad, coolant, engine, front, leak, leaking, leaks, mercedes, running, water
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
