Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > 190E (W201)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-20-2010, 07:36 AM   #1
Drives: 1991 MB 190 E 2.3
Throttle Cable End - Rubber Fitting?
In driving our 1991 190 2.3 the other day the gas pedal went to the floor. I idled the car to the side of the road and opened the hood.
It was easy to see that the throttle cable had worked its way loose from the throttle linkage. I turned the throttle cable ball end sideways so it would stay locked on the throttle linkage.
There appeared to be a rubber fitting that fit inside the linkage that holds the throttle cable end in place. Over the years this rubber fitting looks to be pretty beat up which I think caused the cable end to slip out.
Can I get this rubber fitting as a separate part or do I need to go get an entire throttle cable?
To remove this ad, register today or login if you already are registered!
Rauhbatz is offline   Reply With Quote
Old 10-08-2010, 01:49 PM   #2
Mendez3786's Avatar
Drives: 91 190E 2.6L
Send a message via MSN to Mendez3786
Click the image to open in full size.
1984-1993 Mercedes Benz 190E - OES Genuine Throttle Cable Guide
http://www.thebenzbin.com/parts/?N=1...668+11921+6751
__________________
Mendez3786 is offline   Reply With Quote
Old 10-08-2010, 10:52 PM   #3
That's what broke...thanks!
Old 10-16-2010, 03:42 AM   #4
Mendez3786's Avatar
i found a couple around my spare parts bin.
pm me your info, i'll send you one free of charge.
__________________
Tags
190e, 1991, 26, accelerator, ball, cable, end, fitting, fittings, loose, loosen, mercedes, pedal, rubber, throttle
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
