Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > 190E (W201)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-06-2011, 08:47 PM   #1
Drives: 1985 190E
BAD Air con noise!
New to this site but hoping someone can help me. Just brought a 190e 1985 and have 2 issues - air con works fine but has a shocking screetch that come and goes (sounds like a dentist drill!) also the power steering when turning to the right is really heavy. Any advice would be great...
To remove this ad, register today or login if you already are registered!
lfletcher is offline   Reply With Quote
Old 11-06-2011, 11:16 PM   #2
DRACO's Avatar
Drives: 85 911 Targa
Send a message via AIM to DRACO
Check the power steering fluid level.
Also the refrigerant may be low, system will still work if levels are low but the compressor will work on overdrive to keep up the system.
__________________
[ Lexus ESleft]85 911 Targa My Baby
93 190E
96 Lexus ES300
S430 RIP[/left]
DRACO is offline   Reply With Quote
Old 11-07-2011, 05:35 PM   #3
Drives: 1985 190E
Thanks for that, power steering fluid was fine, weird thing is that the steering is fine when the engine is cold, when warmed up (and just turning right) the steering is harder to turn. Strange.
Old 11-07-2011, 06:26 PM   #4
Drives: 190D, 190E 2.6, C240, C43, C220cdi
Check your drivebelt tension, it maybe loose which will explain both the screech and the weak powersteering.
Ausmbtech is offline   Reply With Quote
Old 11-09-2011, 06:24 PM   #5
Drives: 1985 190E
Thanks, we checked the belt and it is super tight. The air con noise is coming from just inside the vents so maybe a bearing (the noise starts and stops)? May have to get a mercanic to check the power steering. Just so weird how it is just when turning right, (reversing and turning left no probs)
Old 11-15-2011, 04:14 AM   #6
Gullwing's Avatar
Drives: 1987 190E 2.3
Sounds like the bearings in the blower motor. You can take it apart and add a little transmission fluid to the bearings to make the noise go away for a while.
__________________
Give a man a fire, he will be warm for a day.
Set a man on fire, he will be warm for the rest of his life!
MBWGCM #59
Quote:
Originally Posted by Air Marshall Eldritch View Post
Hi there. You are nice.
Quote:
Originally Posted by revstriker View Post
I'm pretty sure there is no recovery from death.
Gullwing is offline   Reply With Quote
Old 11-17-2011, 07:42 PM   #7
Drives: 1985 190E
Thanks ...... Will that require taking the whole dash apart?? or can you get to the bearings a simpler way like taking the aircon vents out?
Old 11-27-2011, 12:51 AM   #8
lsboogy's Avatar
Drives: 2002 CLK55, 1993 190E, 1975 230C, 2007 E350
engine compartment
Blower motors on most benz are accessed from the engine compartment, not a hard thing to do. Check Peach Parts and 190rev.net for a lot of instructions on these things. I did my daughter's in two hours, not working too hard either.
http://190rev.net/forums/showthread.php?t=34141
__________________
AMG Orphan #57
lsboogy is offline   Reply With Quote
Tags
190, 190e, 201, air, car, conditioner, conditioning, fluid, hard, inside, level, mercedes, noise, noisy, power, steering
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
