You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Today I was driving my 16v and all of a sudden i start smelling burnt oil and then my oil level indicator turned on. I pulled over to check and hydraulic fluid was overflowing out the sls reservoir cap,also there was almost no oil in the engine. I tried to tighten the cap as best i could and put some oil in engine. I started it and let run for a few minutes and it was still leaking from the cap. I drove it home and the engine oil level was fine but the hydraulic fluid was still leaking from the cap. Does anyone know what the problem could be and is it super expensive to fix?
To remove this ad, register today or login if you already are registered!
