Sign in using an external account
| 190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: Mercedes Benz 190E 2.3-16
#2 |
If I were you, I would drain the tank, and give it new fuel with an
injector cleaner. Also verify the oil viscosity, color, etc. check the transmission oil also. You'll like it a lot. hmarmaizmd |
#3 |
Drives: 1966 250SE Cab, 1985 500SE Euro, 1985 190e 2.3-16 AMG, 1986 300E LeMons Car
I'd want to drain the tank then fill it up with high octane stuff and drive for an two hour highway cruise. The best hood pads come fom Mercedes, and they don't cost too much. There is a best procedure for getting it on though. Do a search here or on BenzWorld.
__________________
![]() 1994 w124 E320 wagon 1985 w201 190E 2.3-16v AMG 1986 w124 300E LeMons race car 1971 w109 300SEL 6.3 vintage race car Last edited by POS; 04-12-2012 at 11:40 PM. |
#4 |
@POS Premium 93 octane fuel is quite expensive, around $4.30 here in Northern Virginia.
I know I said a lot but my main question is what exactly does old fuel do to the fuel delivery system or the engine of a car? I heard bad things about it, but for some reason our Benz starts up and idles fine on two-year old fuel (only thing is, I'm scared to rev it beyond 4,000 RPM). Maybe the fuel tank hasn't been venting off fuel vapor? I will post a video later on if you guys want proof. |
#5 |
Drives: 87 2.3-16v
be warned that 16v are the most expensive cars to fix for this time frame...several parts are unique to the car and not easily to be found/had. that being said for what it's worth depending on the condition i'd put historic tags on it...especially if your only going ot be driving it around on the weekends
hood pads can be found on ebay for about $50... since it's been in storage i'd advise draining and flushing ALL FLUIDS, oil, gas, brake, rear diff, radiator, even the window washer fluids... circulation is one thing for storage, but to start driving it around for long drives is another...don't risk having to replace items just because your too "lazy" (not that you are) to do proper maintenance i'd also suggest joining us on benzworld.org and 190.rev...there are alot more 16v members on those forums than here.. |
#6 |
Drives: (1) 1986 & (1) 1987 Mercedes-Benz W201 190e 2.3-16 Cosworths
#7 | |
Quote:
#8 | |
Quote:
#9 | |
Quote:
__________________
![]() 1994 w124 E320 wagon 1985 w201 190E 2.3-16v AMG 1986 w124 300E LeMons race car 1971 w109 300SEL 6.3 vintage race car |
#10 |
Drives: 2008 c350 SG - 2004 c240 Wagon BS
Don't crash the damned thing !
#11 |
Sorry for the late reply. Thanks though; I'll take it to a garage to change out the fuel and stuff; the fuel pump and injectors are brand new ones installed in last service, and we put less than 8 miles on it from the occasional neighborhood cruises. I wonder how old fuel hasn't caused this engine to knock and stuff like that; it does idle roughly sometimes but still idles at around 800 RPM so pretty much normal .
| Tags |
| 16v, 190, 190e, 1986, 2012, 23, 2316v, 93, benz, gas, mercedes, notthern, octane, va, vapor, w201 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
