Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > 190E (W201)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-06-2012, 11:10 AM   #1
Drives: 1991 MB 190 E 2.3
Is a ball joint replacement doable for an oil changer?
Hi MbWorld community...thanks for the steer on the wobble issue over 65mph+ with my left front wheel.
Is a ball joint replacement doable for someone who just does oil changes? I can always go get a Chiltons manual if thats what it takes.
I have a fair amount of tools...just curious if there is something special from a Mercedes standpoint
To remove this ad, register today or login if you already are registered!
Rauhbatz is offline   Reply With Quote
Old 05-11-2012, 08:50 PM   #2
Drives: 87 2.3-16v
it's not a special replacement...it's a PIA replacement depending on if you get new bolts or not. the A-Arms tend to seize in so you have to beat them out occasionally. and you'll need access to a press if you plan on replacing the ball joints themselves...or you could get new a-arms with the ball joints already pressed in either way it's still a semi large undertaking, plan on atleast a day for each side at worst case.
__________________
'87 2.3-16v Pearl
'87 2.3 #5
'93 2.6 for sale
Turnpike is offline   Reply With Quote
Old 08-06-2012, 11:56 AM   #3
Drives: 98 E320, 90 300E, 93 400E
Doable...yes. But you will need the right removal/install tool. Removing the ball joint from the steering knuckle will also be a challenge....don't use heat !
__________________
Brian
Brian McL is offline   Reply With Quote
Old 08-23-2012, 12:53 AM   #4
Sincity's Avatar
Drives: '86 190e restoration project, '08 Acura RDX, '09 C63 AMG
Don't forget about the proper spring compressor.
__________________
"Unofficial Member" of the Vancouver Benz crew.
Sincity is offline   Reply With Quote
Old 08-26-2012, 12:33 PM   #5
Thanks all! For certain this does not sound like a back yard oil changer gig...thanks for the advice!
Old 08-30-2012, 02:14 AM   #6
SPONSOR
PelicanParts.com's Avatar
Drives: Porsches, BMWs, Mercedes-Benz, MINI Coopers and more!
Pelican Parts Pelican_Parts
Answer
I disagree.
The control arm does not need to come off.
There is no reason to touch the spring.
I can assure you it is not rocket science.
Take a look at this creative home made ball joint press.
http://www.peachparts.com/shopforum/2750527-post2.html
roy@pelicanparts.com
__________________
Pelican Parts
The One-Stop Shop for the DIY Mechanic!
1600 240th Street | Harbor City, Ca 90710 | T: 888.280.7799 | Like us on Facebook!
PelicanParts.com is online now   Reply With Quote
Old 12-01-2012, 08:51 PM   #7
Thanks all...new ball joint works great!
After finally having some time off off the road to have the left ball joint replaced Im very happy to say that this was the problem of my wobble.
My mechanic replaced it yesterday and now it drives on the freeway smooth as silk and goes like its on rails.
BTW if any Mb World posters live in Ohio I would recommend Tatrai Motors in New Albany...its a single owner shop that does all the hard work for shops around the central ohio area....and is very much into all types of German machinery; even has a WW2 BMW sidecar motorcycle!
Thanks again MB World posters for your help...
Next stop in the journey of my 1991 190 E 2.3 is to replace the radiator...works great while underway but if I stop for a while the temp gauge goes up to 100C...
Old 12-02-2012, 03:00 AM   #8
Drives: 2002 E430, 98 ML320
I live in the Gahanna/ New Albany area and have never heard of this guy. And a google search didn't turn up anything.
Vander is offline   Reply With Quote
Old 12-02-2012, 07:55 AM   #9
Tatrai Phone #
Hi Vander...Mr Tatrai doesn't advertise...most of his business comes from dealers and existing customers.
A few years back when I moved back here from ATL I was looking for a local repair shop for our MB's. Germain and Crown do the work on my wife's newer (2007) ML but I wanted someone local for my 190E; its an airport car that gets driven to Port Columbus for biz travel and runs to the grocery store.
I asked around some of the auto parts places and they recommended Tatrai. They all said don't be put off by the modest surroundings (its a big cinder block garage behind his 80+ year old fathers house off Morse Road just south of New Albany). But when I walked in an saw all of the German motorcycles and as well as nearly new S500 awaiting repairs knew I found the right place for my 190E.
Ive had him replace the ball joint, water pump, serpentine belt and a few other things over the years. No credit cards but check and cash will do. Only works weekdays...don't expect loaner cars and free latte's but he does do a great job and really understands the MB marque.
His phone is 614 855 7079.
BTW MB's run in his blood. His father was former Hungarian WW2 air force and knows all about BD601, 605 and other MB aircraft engines....
Tags
190e, 1990e, 1991mb, ball, benz, failure, front, joint, joints, mercedes, replace, replacement, w201, wheel, wobble
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
