190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
190e 5 speed
Old 05-23-2016, 11:35 AM
Aric91's Avatar
'89 190e 2.6L 5 speed
190e 5 speed
I recently purchased an '89 190e 2.6L 5 speed and it has some grinding shifting from first into second. If I double clutch it and shift at a slow speed it shifts like butter but anything outside of that sweet spot doesn't sound too good. It's been suggested that it could be the clutch brake or the synchro need replaced. (When people say clutch brake are they referring to the pressure/friction plate?) Any suggestions on what the problem could be?
Old 05-23-2016, 12:53 PM
Aric91's Avatar
Correction
When people say clutch brake are they referring to the pressure plate?
Old 05-23-2016, 06:40 PM
Jay Gibbs's Avatar
Many
A "grind" of "buzz" as you describe going from first to second is probably a worn synchro. Double clutching or slowly shifting from first to second will usually keep it from grinding as much...Typically, the faster you upshift from first to second, the problem will seem worse.
J.G.
Old 05-23-2016, 07:20 PM
Aric91's Avatar
J.G.
Thank you. Is that something that can be repaired without doing a complete rebuild on the tranny. A local transmission shop said I needed new everything and quoted about $2000. I prefer to do the work myself but this car is a lot different than what I'm used to (2nd gen Chevy pickups) so I'm new to the German engineering.
Old 05-23-2016, 07:49 PM
Jay Gibbs's Avatar
Many
I've had the problem on a past car...pretty common problem on higher mile manual trannys, but it was never bad enough that I felt the need to have it fixed. Slower shifting generally helps to live with it, but to repair it will require pulling the trans and taking it all apart. Not sure of the actual cost to do this, but it is a big job and will not be cheap. Given the need to R+R and disassemble everything anyway probably justifies the cost for a full rebuild...
J.G.
Old 05-23-2016, 07:53 PM
Aric91's Avatar
J.G.
I think I'm gonna live with it for a little while. I just wanna diagnose it for when I have extra money lying around. I appreciate your feedback though, really helpful
Old 10-27-2016, 05:10 PM
Dato55's Avatar
2005 e55
Hi I'm having the same problem but mines 3-4, did you end up fixing or replacing?
Old 10-27-2016, 05:29 PM
Aric91's Avatar
no i haven't fixed it just shifting in the sweet spot lol. Got it looked at and was told it's the synchro.
Old 10-27-2016, 06:23 PM
Dato55's Avatar
2005 e55
I already have the engine and trans out but I need to find a 5 speed for it
Old 03-06-2017, 10:33 AM
Max Thrust's Avatar
G's + 190
Have you changed the transmission fluid? It may be old and dirty.
Also how are the bushings in the shifter? If the shifter is sloppy, then it may not be putting the transmission precisely and cleanly into gear, so then you can get a grind, etc.
Simple stuff first.
Quick Reply: 190e 5 speed
