190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Rough Idling After Tune-Up
Old 12-21-2016, 03:31 PM
Marcus Barrera's Avatar
190e
Question Rough Idling After Tune-Up
I have a 1984 190e 2.3 with a 5-speed. I recently brought it back to life after 10 years of being parked. I gave it a tune-up which included new plugs, wires, cap, rotor and oil change but I am still having problems starting it when it is cold. In order to start it when it is cold I have to spray starting fluid into the intake. Once it starts I have to keep the RPM's up or else it will shut off. After a couple of minutes of warming up it can idle at low RPM however it idles very rough and the car shakes violently. When I drive it I can feel some fluttering when accelerating in each gear until it speeds up. Once the speed increases the fluttering goes away. Please help. Thank you in advance.
Attached Thumbnails Rough Idling After Tune-Up-benz-190e.jpg   Rough Idling After Tune-Up-benz-190e-front.jpg   Rough Idling After Tune-Up-benz-190e-side.jpg
Old 12-21-2016, 04:07 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
are you sure you got all the wires on correctly? Cold start valve? also jeck out 190rev. Way more action over there and on FB
Marcus Barrera (12-21-2016)
Old 12-21-2016, 04:13 PM
190e
Thanks insame1. Yes I got it wired up right. The timing is 1,3,4,2. Why do you think it could be the Cold Start Valve?
What is 190rev? I'm new to the forums so please excuse my dumb question. Thanks for your response.
Old 12-22-2016, 09:59 AM
insame1's Avatar
the reve is a 190 dedicated forum. I meant to say the idle control valve. Also look under the throttle body for cracked rubber. Changing all the vacuum lines is relatively cheap and will fix lots of issues.
Quick Reply: Rough Idling After Tune-Up
