How to remove the engine cover?
2009 C63 amg
Hello guys
I need some helps, who can show me how to remove the engine cover of the A45?
Really appreciate if you can help!
Cheers!
Cheers!
Piece of ****! There are four mounting points with rubber grommets under the cover. Grab the cover by the either side at the rear and pull directly upward. You'll have to do this for the front two also.
Sometimes it can be a little stubborn, so you may have to do one at a time. No worries just give it a good tug upward on each of the four corners and Bob's your uncle.
Cheers
Cheers
