FS: Bilstein B16 PSS10 Full Adjustable Suspension Kit
GLC 63s
Bilstein B16 PSS10 Full Adjustable Coilover Suspension Kit
10 settings for parallel damping adjustment
Rebound and compression phases can be selected in parallel via the adjusters with the unit in situ
Individual settings ranging from extreme sportiness right up to the highest level of driving comfort
Threaded body adjustable range of 20 mm at both axles, while installed
Lowering of approx. 30-50 mm at front and rear
Road-tested by BILSTEIN under motor sports conditions and fine-tuned
Spring plates and lock nuts made from a special aluminium alloy
Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
Round threads for perfect handling
Quality sport springs made from highly durable material
BILSTEIN mono-tube/Upside-Down technology, made in Germany
Gas Pressure; Monotube; Threaded Suspension (height adjustable); Mechanically adjustable shock strength; Built-in adjustable;
Part Number - 48-141147
Will also fit other C Class W204:
See here for more info - http://www.ebay.com.au/itm/181514166...84.m1555.l2649
$1500
Local Pick Up in Melbourne Only
$1500
$1500
$1500
check your private mail
regards
