Comand 2.5 help
Comand 2.5 help
Does anyone know if i can run a comand 2.5 unit on a bench or does it need to be connected to the car to work?
Also does anyone have the pinouts for this unit and what the plug assignments are?
thanks
Jase
thanks
Jase
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Well, it "runs" on the bench. It depends what your intended purpose is on the bench. (GPS to tell you where the bench is?)
-s-
-s-
thanks
Jase
thanks
Jase
Thanks for the reply guys, the reason i wanted to test on the bench is i dont have the car to test properly.
I fired it up yesterday and it all functions great apart from the nav, when you select it it says an error has occured, i have been told the this unit requires a link lead to go from the nav connector at the bottom to a connector in the top of the housing, does anyone know if this is correct? if so does anyone have a part no.?
I called the dealer but they wouldnt talk to me without a chassis no.
Regards
Jase
Regards
Jase
Regards
Jase
Regards
Jase
-s-
