Sign in using an external account
| Audio & Electronics Use this forum to discuss audio and electronic upgrades for your Mercedes-Benz. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Tap into mic wires c230
__________________
1997 Jeep TJ 2006 c230wz 1981 corvette (Sold) :( 2001 Yamaha R6 ![]() ![]() ![]()
#2 |
Found the mic in teh rear view mirror
![]() But it still has more wires than I had hoped, I am assuming it is amplified or something. From the mic it has the following wires: Purple Green Yellow Red Brown White Thicker From that harness the wires go to a different harness and change color Purple > Pink Green > Purple Yellow > Baby Blue Red > Green Brown > Orange White Thicker > Blue I do not even know where to begin on testing the wires to determine which to use to a 2 wire mic hook up. I do have a very good Ohm voltage meter but do not know what to look for. Any suggestions
__________________
#3 |
The dual-microphone array in your car is indeed amplified and has other processing to optimize it's performance with Teleaid and the factory Hands-Free system.
If I were you, I'd first try to use the microphone included with your PC because it was probably already optimized with your system. This is important because microphone gain and response are critical tuning parameters needed to acheive good VR performance. In other words, even if the factory MB micophone array is better than the one included with your system, your system may not be "tuned" correctly for it. Your time might be better spent doing a clean installation of the mic included with your kit. In any event, the entire mirror assembly is a shop-level replacement part so internal diagrams do not exist for this part in the US. Your only hope for a print of the micophone array will likely be from the actual tier III supplier of the part. |
#4 |
Ok thank you very much for your response. That was my fall back was to you a pc mic and maybe mount it in the vent. I have some friends from work donating 2 for me to try to see if I can get them small enough to mount some where un noticeable but still pic up a decent signal. I will keep everyone posted on the project!
__________________
#5 |
Just another hint: Mounting the microphone in or near a vent is a bad idea. The wind and fan noise will make it useless. Even the stock mirror location can be compromised if the AC vents are pointed up and the resulting air rushes over the face of the mics.
#6 |
I plan on making a small shroud for the mike and worse case i will just turn off the AC when i use bluetooth. Small price to pay for a hidden mic
__________________
| Tags |
| 1997, 2006, array, c230, location, mercedes, mic, microphone, tap |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
