Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Audio & Electronics
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 12-11-2010, 06:36 PM   #51
Drives: 2005 SL500, Black on Stone
Update to SL500 install
More info on my install. I downloaded a free Android application today--called Lazy Car. There are a few others like it...but this seems to be the best.
It allows me to auto-answer calls on the phone, without needing to use the COMAND system. This gets around one of two problems I've discovered using an HTC Evo for incoming calls. By auto answering, I no longer need the COMAND or steering wheel buttons (which were not working).
In Lazy Car, there are a bunch of settings...one of them is delay for auto answer. I set it to 5 seconds. You can also set it to go to Bluetooth or to Speakerphone automatically upon call pickup.
My goal was to be able to auto answer and use Bluetooth (BTA1500) without any intervention on my part.
Half true. The COMAND shows the call coming through, the call is auto answered by the phone (Lazy Car), but the phone does not auto route that call through Bluetooth upon pickup. It requires me to go into the phone menu and hit the Bluetooth On setting. A couple of clicks, can be done quickly, but not optimal.
I tried several other apps with similar results. The Lazy Car app and a couple of others noted that the auto answer feature with Bluetooth enabled does not work on HTC phones specifically. I wonder how this would work if I didn't have an HTC?
They claim to have a fix coming for HTC...I hope it comes along soon. It would be great to auto answer and go straight to the BTA1500.
Hence, I have the setting to route the call to Speakerphone after automatically answering. At least I can hear the call initially, and then I can manually switch over to BTA1500.
Jazzphile
To remove this ad, register today or login if you already are registered!
__________________
I couldn't stand the Lexus any longer....
jazzphile is offline   Reply With Quote
Old 12-24-2010, 03:26 PM   #52
Drives: '06 E55
Very informative thread but i still need some clarification and i hope you guys are patient enough to answer my questions.
My '06 E55 has Navigation/HK sound system. I would like to get an IPOD/hands free Blue tooth so does DG 500 be able to provide that ? How do i know if my car is fiber optic equipped or not ?
Can i get a USB IPOD /phone charger installed in the center console ?
Any good installers in around KY ?
Faast is offline   Reply With Quote
Old 12-25-2010, 11:06 AM   #53
Skylaw's Avatar
Drives: 2005 S500 4-Matic, 1978 450SL
Your car definitely has fiber optics for the audio system, and the original writeup has plentiful photos of what the fiber connectors look like (though their locations will differ in your car). If you have doubt as to whether the GW 500 is suitable for your car, check the compatibility chart on the Dension website.
The GW 500 for MOST fiber optics does offer an iPod integration with a Bluetooth add-on option; however, you could also check InCarTronics/mObridge for their combo units. When you must add both the BT and the iPod functions, the CarTronics or mObridge units may be easier to set up; however, they also require you to give up your CD changer, which the GW 500 does not.
My GW 500 iPod installation charges my iPhone, as mentioned in the writeup. It has separate USB and RCA input as well, also mentioned. I have no idea if it is compatible with the iPhone cradles sold for use with MB iPod integration kits.
__________________
Warren
2005 S500 4-Matic with
Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500 with
Ice>Link Plus iPod integration,
MikBox, and Upgraded voice control
Skylaw is offline   Reply With Quote
Old 12-25-2010, 06:03 PM   #54
Hi,
Just one last update to my install of the GW500. I have a 2005 SL500.
Unit generally works well. Occasionally there is a hiccup with something or other and I have to turn off and on to reset whatever glitch occurred. But this is unusual and in general the system works well.
Ipod functionality is the most reliable. Bluetooth audio streaming also works well but seems to stop by default after 30 minutes. This might be a phone setting and not related to the GW500--not sure yet. I have not tried the USB device option. Aux-in works well but I don't use it.
Bluetooth phone calls work well but with some limitations as I mentioned above. I'll summarize my situation, with one significant improvement since I last posted:
1. 2005/6 versions of MOST do not allow phone book upload from modern smart phones like the HTC Evo. Manual phone book entry and storage works in COMAND, and displays correctly when the call number matches what is in the phone book. I have a feeling that I could figure out a workaround for this--such as loading my Evo phonebook onto an older cel phone and then uploading, or loading to my computer and uploading via bluetooth, but I haven't bothered. It has to to with Object Push Profile and other methods of pushing the info via bluetooth to the COMAND phone book. Technology has passed by this version of the COMAND.
2. Phone/song information is not displayed in the speedo cluster, other than CD# and track # when playing Ipod. Phone calls not displayed in speedo cluster at all. All Ipod and phone info is properly displayed on COMAND.
3. Earlier I mentioned my HTC Evo would not auto answer to bluetooth with the "Lazy Car" application I downloaded. This issue is fixed. A recent HTC update for the Evo seems to have fixed this problem. So now, I can use the auto answer functionality of the Lazy Car application to have the Evo auto answer phone calls, directly to bluetooth.
Even though the SL500 COMAND and steering wheel controls don't work when trying to answer calls thru bluetooth, the Lazy Car auto answers after 2, 5 or 10 seconds (user setting). I can answer the call without any intervention. In some ways, this is actually better than the original in-car functionality in that you are not distracted from the road, don't have to use the steering wheel or COMAND buttons to answer the call.
The only drawback is you can't reject calls without going to the actual cell phone before a call is auto-answered. There are settings within Lazy Car to auto answer all calls, only answer calls in your phone book, etc. I have it set to auto answer all calls.
All in all, after using the GW500 and BTA1500 for some time now, and with the Lazy Car working properly with the HTC Evo, I would have to say that this setup has met or exceeded all of my needs and has met my hopes for functionality. It is not perfect, but it's well good enough based on what it costs vs. the MBZ phone kit and Ipod kit (separate, expensive, and the Ipod kit is not really available thru MBZ for the 2005 SL500).
I suspect that if you are using an Iphone, the auto answer functionality must exist in either the Iphone or a marketplace app you can download. This is the most critical piece that was lacking in the implementation from Gateway/BTA1500 and the SL, but now easily worked around.
I can now heartily recommend the GW500 and BTA1500.
If you are only interested in the Ipod functionality of the GW500, I give the GW500 an unqualified recommendation.
__________________
Old 12-25-2010, 10:52 PM   #55
Skylaw's Avatar
Thank you for posting your experience with the GW 500 and BTA 1500 combination, jazzphile. Detail was excellent.
__________________
Warren
Old 12-27-2010, 12:31 AM   #56
Skylaw,
Thanks....your work in this arena has been the most informative and extensive of anyone on the web, not just on this forum and benzworld. You have helped so many with all of your work. A big thank you.
I thought I might get a rise out of you with my Bose rant in one of my earlier posts, but I was disappointed to see that you did not bite.
Happy New Year!
Jazzphile
__________________
Old 12-27-2010, 09:12 AM   #57
Skylaw's Avatar
Thanks again for the kind words, jazzphile.
Personally, I like Bose - I don't argue that it is the best out there; even the optional upgrade THX-certified system in my wife's '05 Town Car is much better, for example. I would like "tighter" bass response in my S500 - much like the Bose system that was in my '00 Audi A6, with two 8" subs, stock. And, if I could trade out the system in my car for hers, at reasonable cost, I would in a heartbeat.
But I also know that folks' hearing differs, and believe it is not worth the money to pursue statistical performance figures unless you can actually hear the difference - and then, consider whether the difference is worth the delta in cost.
For some folks it is; judging by your screen name alone, you would pursue it where I (with some hearing loss due to flying jets for 20 years) might not.
I do know that the direct fiber optic input of the Gateway 500 or some of the competing systems by InCarTronics and mObridge beats the heck out of using the MB AUX input, which compresses the input even beyond whatever compression is used in the playback device. Floobydust did a pretty good set of measurements that bears out what my ears had told me anyway. http://www.mbworld.org/forums/audio-...way-500-a.html
And, for my ears, the audio quality of DVD sound tracks (not the .mp3 DVD capability, but original commercial DVD sound tracks) is quite good on my stock Bose system - except for the lack of sufficiently tight bass. We can't display the video - but the audio on music DVDs (e.g. the Rolling Stones' Steel Wheels Tour) is the best of any of the input options.
__________________
Warren
Old 12-28-2010, 03:48 AM   #58
Skylaw,
I won't disagree with some of what you said. Previous to my SL, I owned a 2002 S430, so I would have to agree that this iteration of the BOSE system was MUCH better than the one in the SL500. I would trade my BOSE for that in the S Class in a hot minute.
I also had an E Class with the Harman Kardon Logic 7 system, and I'd have to say that this was better than either iterations of the BOSE system.
When I bought my SL, I was APPALLED at how awful the sound quality of the system was. I was driving home from Vegas and played endlessly with the system....ending my trip frustrated by how far a step back I had taken with the sound quality.
That said, now with the Dension and the ability to EQ (anathema to me in any other setting) via the Ipod, I can get the system to at least sound decent.
But I will admit, I'm an audio snob. Audio Research, Conrad Johnson tubed equipment, KEF speakers, Martin Logan speakers, Thiel speakers, etc. etc. So I'm used to high end sound quality and know what is good and what is not good.
Again, my compliments to you for sharing all of your knowledge. I can't tell you how many times over the past 2 years I've read the threads to which you've contributed (Gateway 500 and others). It is largely through your writeups that I finally convinced myself to pull the trigger on the Dension.
Happy New Year.
Jazzphile
__________________
Old 12-28-2010, 03:52 AM   #59
I must add two things that frustate me about the SL BOSE system:
1. The mid-bass hump is absolutely horribly pronounced. This is where the EQ of the Ipod comes in handy. But stock and set to neutral in the BOSE, it's almost unlistenable.
2. The surround implementation in the SL is horrible as well. Very little sound from the rear, and that which does come from the rear is so processed as to almost be unuseable. It's sort of distorted and processed at the same time, and only in the high end of the midrange to add slight "ambience".
Lastly, another thing that frustrates me about the BOSE in the SL: While you have surround modes in line sources like CD, DVD and Dension, when listening to FM, you only have the front Left and Right speakers, with no additional sound processing. FM sounds absolutely attrocious on the SL BOSE system. Simply unlistenable if quality is important to you.
__________________
Old 06-14-2011, 10:23 PM   #60
Drives: 2006 S430
Hey guys, 1st post here. I purchased a 2006 S430 today and was shocked to find no aux in. The Denison Gateway 5000/GW51M02 seems to be the best choice for me, but I cant tell clearly if it will work or not. Its listed on the compatibility list. Stupid question, but are there 2 parts? The 5000 and the GW51M02? I definitely am too scared to install myself, so I have a friend who is a tech and he will install it for me. Anything I need to tell him? Thanks in advance for taking the time to answer this newbies question
alexwolf1216 is offline   Reply With Quote
Old 07-18-2011, 02:07 PM   #61
Drives: w164/500
I can't get the BTA1500 work
I install gw500 with BTA 1500. I paird iphone4 no problem, but when I press the
TEL button on the Command unit, It says Phone not available. I cant upload my phone book, cant answer the phoes or make a call from the steering wheel or Command unit. What I am missing here?
(I have Motorola phone unit from factory under the rear driver seat but no phone plug in the arm rest) If anyone know about it please help.
alper is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
12v, 2003, 500, a6, activate, benzworld, bta1500, cdc, d2b, dension, gateway, ipoddension, pin, power, sl500, unswitched
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
