Aftermarket Speaker and Amplifier install pictures
Old 02-01-2010, 06:10 PM
  #51
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by kataboboi
man super nice workkkk...
Old 02-19-2010, 04:47 AM
  #52
peak_oil_101's Avatar
2006 E320 CDI
hi pinebaron, thanks for creating this thread. I'm thinking about hacking the system myself. I just got an 06 e320 cdi wtih the h/k logic 7 system, but it sounds really bad. it's way underpowered.
First off the center speaker is blown/rattles. I'm thinking about replacing it with 2 mid range 4ohm speakers wired together so the resistance is 2ohm. (read this is possible on the internet) I might put these speakers above the feet of driver and passenger. The current system gives the center channel too much power anyway so I'm hoping this will make the system sounds louder.
I would like to add an AMP but I keep reading that I will blow my speakers if I try to run a 4 ohm AMP. Ideas for imporving without spending 2k are greatly appreciated.
Old 02-19-2010, 06:03 AM
  #53
bheng's Avatar
2003 CLK 320
just my 2 cents but
run a 4ohm amp to new speakers and have that connected to your original deck via hi/lo converter. you will get a more powered set of speakers and it wont kill your wallet.
Old 02-19-2010, 05:17 PM
  #54
pinebaron's Avatar
07 E320 Bluetec
I did not power the center channel speaker but powered OEM door speakers with a 2ohm/4ohm amp. There are a few good 2ohm amps around. Drive OEM speakers if these are good heavy ones as in W211 MY07 (like mine), you may not need to change door speakers; remove a speaker and take a look. I drive 100Watts+ rms into each door component speaker set with a 4 channel amp, you see in my thread; I purchased it from an authorized dealer at full price. A new 4 or more channel amp and 2 pairs of new decent door component speakers can easily end up around $2k. I say change only what is immediately required.
Your center speaker may (or may not) be a dual coil speaker; one easy option may be to replace it with another OEM speaker which will get rid of rattles.
For more overall sound from doors, follow my example or use a 5 channel amp if you intend to power the sub but a new sub may be required. Look what another member in this thread has done.
Keep it simple and manageable:
1. Replace center speaker first; why bother with more wiring but do what you feel is best for you.
2. Remove and examine a door speaker component set to determine if these can handle more power.
3. If #2 above fails then think about two sets of component speakers, 4ohm sets will do and a 4ohm 4 channel amp (5 channel if installing new sub, or 4 channel + 1 single channel for sub). Don't compromise on quality.
Old 02-19-2010, 10:34 PM
  #55
BrabusMan's Avatar
2009 VW CC
Not sure what you mean by a 2/4ohm amp? Please explain? What is a "good 2 ohm amp"?
Old 04-06-2010, 12:12 AM
  #56
2006 E320 CDI
Hi Pinebaron,
Do you have any tips, links or instructions on removing the W211 door panels?
Old 04-06-2010, 12:00 PM
  #57
pinebaron's Avatar
07 E320 Bluetec
I am not home for the next several days and not able to send you the pdf; I would have sent you a pdf. Do a search on this forum on 'removing door panel' and you will be able to locate the right pdf.
Basically you need to remove two torx screws located in the door handle area and another one or two located in the door lock area. Also disengage the tweeter housing which is clipped on to the door panel.
Let me know if you located the mercedes benz door panel removal pdf.
Vim
Old 04-07-2010, 06:08 AM
  #58
jbondox's Avatar
beater with a heater
BrabusMan that is the power cable size coming off dem speaker terminals... good think them Audisons have them
Old 04-07-2010, 08:18 AM
  #59
pinebaron's Avatar
07 E320 Bluetec
Hi Pinebaron,
Did you locate the pdf?
Old 04-07-2010, 02:41 PM
  #60
2006 E320 CDI
I think so, thank you.
https://mbworld.org/forums/e-class-w...l-removal.html
Old 05-08-2010, 08:47 PM
  #61
2006 E320 CDI
I attempted to remove the door panel today, but unfortunatly I got stuck at the very end.
All that was preventing the door panel from being disconnected completely was the manual lock pull/knob next to the window. This knob connects to the inner door assembly via a heavy metal wire and I didn't want to break anything so I had to give up.
Anyone know how to disconnect this?
Old 05-08-2010, 09:38 PM
  #62
pinebaron's Avatar
07 E320 Bluetec
You just turn it around (around its pivot point) where it connects to the door handle and it comes off.
E63007 (10-31-2020)
Old 05-08-2010, 11:54 PM
  #63
2006 E320 CDI
There was one metal wire with a rubber shield around it that connected to the door handle? This sounds like the location where I should pivot the wire around until it releases. (I didn't attempt that yet. thanks for the info.)
But there is also a metal rod, running vertically through the door panel, which has the lock/unlock indicator knob on top of it.
Do you know how this detaches?
Old 05-10-2010, 07:07 PM
  #64
pinebaron's Avatar
07 E320 Bluetec
I think you mean the Door Lock Pin. You may not need to detach this; the door panel should clear the Door Lock Pin while lifting the door panel straight up.
Old 05-11-2010, 12:59 AM
  #65
2006 E320 CDI
That might makes sense. I'll take a look.
Old 05-25-2010, 09:38 AM
  #66
ImperiumDon's Avatar
2007 E550 Sport
Pinebaron, your link on the first page is down?
Old 05-27-2010, 06:44 PM
  #67
Ibarra's Avatar
2007 Mercedes E350
pinebaron this is awsome you rock thanks!
Old 05-27-2010, 08:54 PM
  #68
pinebaron's Avatar
07 E320 Bluetec
Thanks. I am in the process of remodeling my basement and the server/racks cabinet was being moved to its new location with better airconditioning and heat control.
Old 05-27-2010, 08:55 PM
  #69
pinebaron's Avatar
07 E320 Bluetec
Old 06-03-2010, 07:21 AM
  #70
pacman...'s Avatar
"MURDERED OUT" 2005 E55 AMG
nice write up its always goo to be innovative and unique, thought that adapter probably would have set you off you are right in one thing why spend $400-600 on one MOTUS adapter while you can still utilize your way with crossovers and filters to clean up sound and still save some money...I give you full props man from someone with tons of experience in audio (but not much with mercedes, just learning) just my .02 cents i'll keep you posted on my E55amg project cause I will be doing a full blown custom system in it...
Old 06-03-2010, 09:43 AM
  #71
pinebaron's Avatar
07 E320 Bluetec
Thanks. I wanted to keep things simple for anyone to replicate or improve upon.
Old 06-03-2010, 07:22 PM
  #72
jbondox's Avatar
for someone with tons of experience, you still have no clue...
do you think taking an amplified signal from the amp (audio gateway) that is processed already is going to get clean via a crossover network? what freakin koolaid you drink? maybe you should let the adults converse...
Old 06-03-2010, 09:09 PM
  #73
pinebaron's Avatar
07 E320 Bluetec
Hubristic again !
Old 08-23-2010, 01:19 AM
  #74
xxrickey21xx's Avatar
2001 ML430
4 12s has a nice sound
Gettin the upgrade started
Old 08-23-2010, 06:29 PM
  #75
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Originally Posted by xxrickey21xx
But where do the golf clubs go?!?!?
Quick Reply: Aftermarket Speaker and Amplifier install pictures
