You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well i have a 1999 ML430 which has the factory BOSE woofer under the passenger seat. However i have installed a new Touchscreen headunit to replace the old tapedeck, however i always get this annoying hiss at any level of volume, then i realised that the car already has an amplifier installed somewhere which must power the speakers and amp. However my headunit has 4x50W amp bult in, so im guessing im sending an Amped signal into the factory amp which is creating the annoying hiss.
Do any of you guys know how I can bypass the factory amp and still maintain the stock subwoofer under the seat? or is this not possible?
I don't really mind losing the woofer if i can get rid of this dam hissing noise!!.
ALso when i installed, i had to cut off the old connector from the old headunit and tap every specific wire to get audio through the speakers, however on the wires in the car, i had to send a constant power source down a wire which i believe told the factory amp to turn on and off. When no power was being sent down, no audio.
ALso where is the location of the stock amplifier?
