You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I posted this in the Tech Forum, but someone suggested I post it here.
I have a 2006 SL500. I recently had to pull the CD Changer out of it and then reinstall it. After I did this my NavigationSystem quit working. Everything was done correctly in the reinstall so I know that's not the problem. After doing research I'm convinced that it can be fixed by getting into the Engineering Mode, but I've tried a bunch of codes to get into the engineering mode and none have worked.
In a thread I started about this problem a guy named eric242340 posted, "The system may need a "wake up call" using Star Diagnostic System to restart the optic ring". Whereas I wish I had the code to get into the engineering mode I would also like to understand how the Star Diagnostic System works. I know it's a shop manual on a CD or DVD, but can it also be connected to the car to perform certain functions and tests and if so what is needed to connect it to the vehicle?
Also, for anyone who has used the Star Diagnostic System, is it worth the money. I ask because I've bought two WIS programs and they stink.
Thanks in advance.
To remove this ad, register today or login if you already are registered!
