Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Audio & Electronics
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-24-2012, 09:50 PM   #1
Drives: E55
Aftermarket W211 headunit upgrade complete
I have searched and found bits and pieces of how to upgrade the radio in the w211 so I decided to do a write up on it. My car is a 2003 e55 with the HK system, so it has the MOST fiber optic system. Therefore, you will need to add an aftermarket amplifier to run the factory speakers.
Here's what is needed:
Aftermarket unit: I went with the Kenwood DDX719 double din.
Click the image to open in full size.
Trim Bezel: From research, the connects2 kit is the best fitting one available so i decided to go that route. It has to be ordreded from UK and I found it on ebay for about $80 shipped to US. It comes with the mounting cage and trim. The part # is shown in the pics.
You will also need a antenna adapter and extension to convert the old antenna to the standard motorola plug. I went with
http://www.metraonline.com/part/Afte...tenna_44-EC204
and http://www.metraonline.com/part/Volk...ntenna_40-EU10 to convert from the audio gateway in the trunk.
I didn't use any radio harness as the factory unit only has 3 wires on the back of the radio. red/yellow is 12 volts, brown=ground, and beige is Most wakeup (not used). You have to tap into the cigarete lighter plug for switched 12V. I didn't care to find the dimmer/illumination wire and i didn't hook up the factory steering wheel controls as I've heard the response of the Swi-jack/adapter is pretty slow.
With that being said, here is the finished product. Still working on getting my baffle/sub right and the mids/highs in the door will be the next step. Feel free to ask any questions if you need any help.
New unit in! Fitment is pretty good with the connects2 kit.
Unit powered up!
Top left of a/c button is my bluetooth mic mounted in the instrument cluster trim
JL audio 12w6 mounted on a baffle board bolted to rear deck
Amp mounted in trunk under cover
To remove this ad, register today or login if you already are registered!
phampau is offline   Reply With Quote
Old 04-27-2012, 12:59 AM   #2
6spdcoupe's Avatar
Drives: '08 TBSS, '06 E55, '09 CX-7
http://www.linkedin.com/pub/don-amann/13/269/482
Steering controls - midcity.
You should a lot more 'wood' for that baffle as well as top mounting.
__________________
'06 E55, '08 TBSS, '09 CX-7
H900/BRAX MX4 x 2
Dyn Esotar 110s~430s~650~1200
6spdcoupe is offline   Reply With Quote
Old 04-27-2012, 06:34 PM   #3
Drives: E55
I read alot of your post on diymobileaudio and I appreciate your suggestions! Midcity is a company for the steering controls? Also, for the baffle, do you think 2 of the 3/4 mdf is enough, so 1 1/2" thick? Thanks in advance. Paul
Old 04-28-2012, 02:57 AM   #4
6spdcoupe's Avatar
Midcity does a lot - remote starts, steering controls, integration for radar, etc. I would choose theirs, despite the cost, over any alternative. They work seamlessly, no learning or the likes. Just works !
Anytime my friend. For that sub, if you must use MDF, then at least 4. With Birch, you can maybe with 3. Density is key for a sub. MDF is surely cheaper, birch is lighter and substantially more dense. You can mix if you would like, such as the final bottom piece with MDF as a chamfer or roundover like MDF much better than Birch.
__________________
H900/BRAX MX4 x 2
Old 04-29-2012, 06:01 PM   #5
Drives: E55
Will give midcity a call this week to see. Wow, 3" of mdf or 2.25 birch for the baffle? I'm not a car audio expert by any means so can you help explain to me what the benefit would be to run 3" thick baffle? Also if you have a moment, can you check out this link to my post and let me know your thoughts? Maybe a thicker baffle will solve my issues?
http://www.diymobileaudio.com/forum/...ggestions.html
Thanks, Paul
Old 04-29-2012, 07:46 PM   #6
6spdcoupe's Avatar
At least, yes. Density is your friend. You are burning up a ton of energy and losing it just in that baffle. You need stiff, rigid and dense. The more the merrier, but there are limitations in a vehicle.
You said you subsonic is 28-30, what is the top end ? At what slopes are they ?
__________________
H900/BRAX MX4 x 2
Old 04-29-2012, 11:11 PM   #7
Drives: E55
I've tried the low pass crossover anywhere from 60hz to 120hz. I've found around 80hz is the best. I'm using the built in crossover from the kenwood ddx719 headunit so i think it's -12db slope. I will do probably buy some birch and do a triple baffle to see if that works. My only issue is i'm bolting the mdf to the rear deck on the factory sheet metal, which isn't really thick to begin with, so maybe the factory rear deck metal is going to be my limitation before the wood ever will be?
Old 04-29-2012, 11:14 PM   #8
6spdcoupe's Avatar
So then your pass band is 28-80 ? What slope is the 28 ?
Non issue with the rear deck. I have done several of these cars with IB configs and no issues.
__________________
H900/BRAX MX4 x 2
Old 05-03-2012, 08:48 AM   #9
Drives: 2008 E320
Looks great. What are you considering replacing the speakers with? My local sound shop said the speaker openings are very shallow (2008 E320) and that it would be hard for me to get speakers to fit.
bfisher is offline   Reply With Quote
Old 05-03-2012, 02:53 PM   #10
Drives: E55
Sorry I missed your post! Been waiting for you to reply, but I guess it was there all along. The 28 is 12db slope also. Here's some interesting info I found today. I pulled the 12w6 off the rear deck, put it in the ported box that it came with, 1.5cu ft. The 45-60hz frequency sounds much better (a little boomy, how I like it), but the lower <45hz sounds/feels much weaker than when it was IB. So the question is, how can i have the best of both worlds? I have 400w @2 ohm and thinking I might try fitting 2 10's or 1 15" on the rear deck for better/more output? I really don't want to run another amp, so if it's doable with the 400w rms, that would be great! Paul
Old 05-03-2012, 02:59 PM   #11
Drives: E55
Quote:
I went with the Hertz 165xl, they are very deep, but I used the factory door baffle so it cleared just fine. The only issue is that the factory door baffle have an angle on them that angles the mids to the front of the vehicle, which really makes the imaging poor. The other thing is that there is literally hardly any room to mount passive crossovers in the doors, so keep that in mind also. All in all, the system sounds much better than the factory HK system, but still not where I want it. Hope that helps. Paul
Old 05-01-2013, 10:27 PM   #12
Drives: E63 Designo, SL65, SL 55 030, ML, bunch of old ones
I know...
this is an old thread, but...I would like to order one of the connects 2 kits for the kenwood unit in my 211. Yours looks and fits much nicer than mine ....can you help, thank you...
allenjdmb is offline   Reply With Quote
Old 05-02-2013, 09:42 AM   #13
jbondox's Avatar
Drives: beater with a heater
Whats funny is that the OPTI-1 that was sitting in a box for 3 years would of worked and no need to replace the factory amplifier.
The connects 2 kit could be found on sonix electronics (not sure of the spelling)
__________________
1st MOST optical integration via OPTI-1
1st 2012 ML factory Bi Xenon retrofit
1st 2010 ML DRL LED integration
1st 2010 CL Rear Seat Entertainment to COMAND integration
1st Successful Maybach remote start integration
jbondox is offline   Reply With Quote
Old 05-02-2013, 10:02 AM   #14
jbondox's Avatar
Also the AWSC1 from Metra, steering wheel controls, I have yet to experience lag on the button push, maybe not installed properly.
__________________
Tags
12v, antennas, car, controls, ddx719, e320, forums, headunit, kenwood, lighter, midcity, mybb, powered, radio, steering, tapping, uppgrade, w211, wires
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
