Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Audio & Electronics
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-11-2012, 01:58 AM   #1
Drives: Jani Raxter
Can a 28 kw 3phase slip ring motor start with any on off switch or it must be a stage
Can a 28 kw 3phase slip ring motor start with any on off switch or it must be a stager starter?
Depends on what kind of load you have on it. I didnt know rotary joints had a motor, but if its a big electric coaxial rotary joint motor it needs a stager to let it change from star to delta configuration, most things that spin have slip rings, you need to be more specific about yur question, normally fiber optical rotary joints are associated with cranes and stuff that spin, and are found in the dead center of a spinning object along with a swivel, or slip rings that allow it to rotate while no cables are attached.
To remove this ad, register today or login if you already are registered!
Jani Raxter is offline   Reply With Quote
Tags
3phase, motor, questions, ring, slip
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
