AUDISON BIT 10 (audio processor) info needed
Old 09-08-2015, 05:22 PM
greasykid's Avatar
2015, ML250 BlueTEC
Am thinking about adding the Bit 10 to the MB standard audio system. Have already upgraded speakers & amplifier. This is supposed to be 1 of the best processors (other than the Bit 1 $900) available.
Appreciate any info or usage you have. Installing in my 2015 ML250. By the way,how much audio do you get from the small speakers mounted in top area of the 2 rear doors? I don't get much of anything. Any other good ideas that I can afford? Planning on keeping this ML a long time. Great car! Thx.
Old 09-08-2015, 10:57 PM
jbondox's Avatar
beater with a heater
bit 10 is a great EQ, done many, done some of the first in the USA. Once it is set though.. it is set. If you have a different selection of music taste get the DRC, as it will allow you to preset eq's (2) and give you master volume control without adjusting the factory volume.
Seeing you dealing with a regular audio company that doesn't have the means to enable/disable the COMAND audio features, most likely the EQ curve will change when you turn the factory volume up/dn or the car on/off.
if you are an iphone user than you can use the Pure i20 with optical output (don't believe it supports the 5 though, never tried it...) you can use the toslink input.
now if it were my vehicle, I would also consider the Alpine PXA-H800 and the RUX controller. I just believe it has a lot more usability and 6 presets. either way, personally I have used both and many of the bit1's
something to ponder
Old 09-09-2015, 11:39 AM
greasykid's Avatar
2015, ML250 BlueTEC
Thx for your Bit ten input. Have not changed anything in COMAND & do not plan to do so. Want complete oem appearance & functions. Volume control will be on COMAND unless we add an outboard DRC. Not familiar with the Alpine products you mention. Have 1pm appointment today with installer. My Bit ten arrived yesterday. Will probably have install sometime next week.
Anything else you can comment on can still be included @ this time. "Randy" has done work for me for several yrs & is flexible.
Old 09-11-2015, 09:59 PM
jbondox's Avatar
If you are committed, and is sounds like you are, do not leave till it is perfect sounding to you. I see a lot of shops set it to a flat response which usually sounds "blah" Don't except it until it exceeds your expectations.
Old 09-12-2015, 12:42 PM
greasykid's Avatar
2015, ML250 BlueTEC
Thx for the advise. Believe me Randy expects to spend more time "tuning" than installation time. I only live less than 15 min away from his shop so can live with it a while & return for any needed adjustments. My backround is as a Mfg. Rep in the audio industry. Repped mfg i.e. BOSE,JBL, AKG,PHILIPS etc. We have had discussion re the deficiencies of the existing system & corrections. No problem returning if necessary. Will post after installation. I purchased the audio components that have been used so far after consultations with Randy.
Old 09-12-2015, 09:15 PM
jbondox's Avatar
Bose? Please tell me that is not a good reference
Old 09-13-2015, 11:16 AM
greasykid's Avatar
2015, ML250 BlueTEC
BOSE COMMERCIAL SOUND !! Never a Bose fan in car audio. I was never involved in car audio. Residential,Commercial & Studio.
Old 09-15-2015, 08:25 PM
Mike5215's Avatar
2016 C300
I just did an Audison Prima 8.9 in my 2010 S550, a DSP with an integrated 8 channel amp. Great sounding unit. If anyone is looking for a compact and inexpensive OEM integration solution, without adding external amps or changing speakers, I'd recommend it.
Make sure on your Bit when the shop runs the initial config they do the de-equalization process. That will remove the factory EQ and give you a flat signal to start with.
Old 09-16-2015, 01:40 AM
G Style's Avatar
w221 Sclass 320 cdi
something to ponder
I have an s class 2006 year w221 and I like the sound in the car but its just lacking in volume for me what can I do to improve this ??? I see you mention Alpine Pxa H800 I have a pxa h701 with the controller that is brand new never fitted I was going to fit it in my last car with all the audio that I had in it. I wonder if this bit of kit is worth fitting in the S class with the oem command system what do think ???? Any advice is much appreciated.
Thanks.
Old 09-16-2015, 12:44 PM
greasykid's Avatar
2015, ML250 BlueTEC
When I upgraded my speakers I also had new amp installed. ALPINE PDX-F4. 4 channel 400 watts. Great improvement & more power than I will ever use.
Re earlier post here. The factory EQ removal was the 1st thing done.
Old 09-16-2015, 09:25 PM
jbondox's Avatar
With a Prima 8.9 on a 221 it lacks enough inputs to sum all the speakers up front, center, and sub. I had to use a pair of bit1's to do it right. separated front and rear. Also Logic 7 needs to be disabled. Further the factory logic 7 system has more power than the Prima. it would at the very minimum need more channels for the amount of speakers in the vehicle, unless you are not amplifying a 3 way up front or using passive crossovers.
G Style, the S221 is a hard vehicle like the 7 series BMW to get right and it is not cheap. navtv was working on a solution for extracting the audio but it really hasn't matured from concept. you should beat them up by emailing derek@navtv.com and ask them wtf? they have the hardware and time into it, but back burner'd it like 20 other cool mb products
Old 09-16-2015, 09:27 PM
jbondox's Avatar
that is a given, give the bit1/10 is preamp out so an amp will always be needed. I am suprised you didn't go the alpine V9 for a sub in the future or a Voce5.1k
Old 09-17-2015, 10:31 AM
greasykid's Avatar
2015, ML250 BlueTEC
Still no decision on when & if will be adding sub. Present speakers respond to 50 hertz. We have a backup plan on a sub if necessary.
Old 09-23-2015, 07:57 AM
Mmr1's Avatar
2013 glk 350
Does the Audison Prima 8.9 have a higher quality sound than the stock unit. I'm not referring to volume, just overall quality. I've just replaced my all my speakers to Hertz 165xl, an amp and processor are next. This seems to be the simplest option, although not the highest quality option. I just put in two sets of Herts 165xl with the stock Becker 20, it made a major difference on overall quality.
Old 09-23-2015, 11:22 AM
greasykid's Avatar
2015, ML250 BlueTEC
Read my previous posts above. Just had Audison Bit ten installed. GREAT SOUND. It wasn't easy. My installer did it on 2 different days. The tuning is a Black Art. After the first session we both took a few days off to listen & critique.We met again to discuss how we would like it to improve. The second session was a GREAT improvement. I have been on this project for over 6 months. The end results are worth it.
Old 09-24-2015, 03:30 AM
jbondox's Avatar
The 165xl's need some power, I remember when they first came out, they were good, no replacement for the Mille 165's though. needed a lot of power. you will be happy when you amp the hell out of them
Old 09-24-2015, 03:57 AM
Mmr1's Avatar
2013 glk 350
I was asking about the guy that did the 8.9, and comparing it to a Audio 20. I'm new to this posting stuff so I don't know if I'm responding in the proper place-location, here.
Old 10-08-2015, 10:31 PM
Mike5215's Avatar
2016 C300
I didn't approach it as if the holy grail was to have DSPs handling every single channel coming off the Becker amp. I left the puny 4" center and rear surround speakers alone on the OEM amp. It's not like they were big producers. The OEM sub in the rear deck got its own small 300 watt JL mono amp, and took signal from the Prima's sub out.
That left the Prima to handle just the front and rear door arrays, which do most of the heavy lifting. We set the fronts as 3 way active, and the rears as two way passive.
Prima Channel Distribution
TW -CH1.................................TW-CH2
MID CH3.................................MID CH4
WF CH5..................................WF CH6
2 Way-CH7.............................2-Way-CH8
CH9 Unpowered
Sub Out --------------------> JL 300------------> Factory Sub
Took very little tuning to blend the three little surrounds into the mix. Great sounding system, lot's of low end punch, clean mid bass, smooth mid range and transparent highs. Not cheap, around $900 for the Prima, $300 for the JL Amp, around $600 labor. I did my own tuning. Here's an example of the config on the left front woofer:
You get this level of control over each individual speaker in the front doors. Level, Filter Type, EQ, Time Correction,
De-Equalization of the factory signal.
The compact Prima and the JL Sub Amp installed:
Old 10-08-2015, 10:36 PM
Mike5215's Avatar
2016 C300
Oh yeah. You're halfway to a killer system. The real value of the Audison is in the digital signal processing. You get so much control to shape the sound its really easy to get stunningly beautiful quality out of it. No comparison to stock.
It'll definitely make the most out of your new Hertz gear. I did a speaker replacement first on my 221 (Focal KRS100 in the front doors and Hertz DSK in the rears) and there was some improvement, but the new speakers are totally different animals on the Prima. The Hertz especially "woke up".
Old 10-13-2015, 06:05 PM
rpr2's Avatar
CL550 W216; S550 W221
I'm considering a similar upgrade to my W216 CL550. My installer recommended I initially just add subwoofers and amp to the stock system to see if that will satisfy my needs; at least for awhile. The stock system does not sound "bad" at all as is, but lacks authority and punch on the bottom which this should cure. I'm using my Diamond Audio D6 1000.1 monoblock amp and two Diamond Audio M6 10D4 subs in a sealed box. These were in my CLS500 and sounded great. I'm having the stock "subwoofer" removed. Mike5215, do you recommend hushmat for the deck and/or trunk in the W216? I want to avoid rattles with the more powerful subs in the mix. Didn't need it in the CLS. If the subs alone do not improve the sound sufficiently, I'll add a processor-- MS-8 or the Prima 8.9. Sounds like the speaker upgrade alone only provided modest improvement; is that correct? I very much appreciated your blog on your W221 install; very helpful.
Old 11-08-2015, 10:32 AM
Mmr1's Avatar
2013 glk 350
Better than de equeing is to get into the Maintenance program on the factory head unit and set it to zero. There are two or three sub pages, EQ and crossover and possibly something else. Better yet is Audison Bit Dmi, optical to optical. But still zero out the head unit or you never will achieve what it should be.
Old 11-10-2015, 06:11 PM
jbondox's Avatar
uhm no, and wrong type of optical
Old 11-10-2015, 07:28 PM
Mmr1's Avatar
2013 glk 350
The Audison rep is doing final set up on my Glk Thursday for the Bit Dmi . I have an audio 20 , and an Audison 8.9. And yes, bypassing the audio 20 eq is best. Bypassing the audio 20s amp and circuits is an improvement.
Old 11-10-2015, 07:33 PM
Mmr1's Avatar
2013 glk 350
I've talked to elletromedia several times about this, they say it works. Call them.
Quick Reply: AUDISON BIT 10 (audio processor) info needed
