Did VIP Destroy My Vehicke
Old 02-18-2017, 09:18 AM
dinows's Avatar
200 e320
The battery was getting bad in my 2009 c class 4matic so I brought it to VIP, They put a new battery in then told me it wouldnt start. Had it towed to the dealership who said it needed a new EIS Module and key. He also said this happens sometimes when you change a battery. I have never heard of such a thing. Could someone give me some answers to this ?? Thanks so much
Old 02-18-2017, 01:29 PM
Aar Sto's Avatar
'04 ML350
sounds like your battery was fine, but your eis was going bad.
Old 02-19-2017, 11:32 AM
dinows's Avatar
200 e320
OK Thanks, is that something that can be replaced by an auto shop or does it have to go to Mercedes Dealer, I guess it needs the new key also, Thanks
Old 02-19-2017, 02:47 PM
Aar Sto's Avatar
'04 ML350
search the forums for eis c class. there are many threads.
Here is one suggesting it could be repairable, which is what you should try to do first - https://mbworld.org/forums/m-class-w...rimlims-2.html
Old 02-19-2017, 03:13 PM
Aar Sto's Avatar
'04 ML350
https://mbworld.org/forums/c-class-w...ttle-help.html
Does the problem change with temperature? The guess would be bad solder joints on the EIS, specifically around the connector pins. That would be odd for that year of vehicle unless you live in a climate of extreme temperatures. If you can get it out and resolder the board, try it. If not, replace the eis.
Old 02-19-2017, 03:16 PM
Aar Sto's Avatar
'04 ML350
https://mbworld.org/forums/c-class-w...-eis-myth.html
