Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Audio & Electronics
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-09-2004, 11:36 AM   #1
Drives: 2003 SL500
Send a message via Yahoo to sarb
Bose speaker upgrade
I am looking to possibly upgrade the speaker system with a sub system and amp. I am wonder if any one has experience iwth this while using the MB command system. Is there a notice difference in sound quality or is it limited by the command, and if so in what way.
Also any speaker system you all may recommend.
To remove this ad, register today or login if you already are registered!
__________________
drsarb
Bay Area, CA
2003 SL 500 Black on Black AMG Sports Package
Mods:
Powerchip Group 93 Gold
Brabus Quad Exhaust
Brabus Lowering Module
Renntech Rear Spoiler
Renntech Carbon Fiber Air Box
Smoked SL55 Tailights
Passport 8500 Detector
Stereo Upgrade:
Focal 165 w3 Utopia
Jl Audio 2-6 inch Subwoofers
Zapco 350 watt Amps - 2
Kept Fill Speaker and Stock Woofer but Amped them also.
sarb is offline   Reply With Quote
Old 04-10-2004, 06:46 AM   #2
clkal's Avatar
Drives: 01' CLK55
Send a message via AIM to clkal Send a message via Yahoo to clkal
Re: Bose speaker upgrade
you can upgrade your speakers to pretty much any brand you want. Whatever you upgrade to, you will find that the aftermarket speakers are a lot more clear and precise. As far as a sub goes, all the installer needs to do is tap into the wire for the rear speakers , hook up a high-to-low converter, and add the sub amp . It's a pretty straight forward install.
i prefer jl audio , mb quart, or focal for my highs. JL audio for subs =)
clkal is offline   Reply With Quote
Old 04-10-2004, 11:56 PM   #3
Drives: 2003 SL500
Thanks for the insight.
Have you ever heard of a/d/s speakers, and how do they compare.
__________________
drsarb
Bay Area, CA
Mods:
Brabus Quad Exhaust
Stereo Upgrade:
Focal 165 w3 Utopia
Old 04-11-2004, 10:11 AM   #4
Super Moderator
amdeutsch's Avatar
Drives: MPG+ ROLFCOPTER
A/D/S speakers are definitely up there.
__________________
amdeutsch is offline   Reply With Quote
Old 04-11-2004, 10:35 AM   #5
Drives: 06 Infiniti FX35, 07 SL55
I am having my SL500 system upgraded next month.
I am going with a trusted installer in Houston (4 hours drive and well worth the trip). They have done several 500s and 55s and know what it takes to get it right.
The most important thing for them to do is pull the command unit and send it out to have it altered slightly. I dont know the details, but I was told that they need to combine the low and high frequency into a single signal for much better audio clarity. I dont know if this is a hardware or software change, but I think it might be hardware. They sent it to NY and it takes three days total turnaround time.
They put two 8" or 10" subs in the passenger footwell, two large amps in the trunk against the back wall with a custom fiberglass enclosure trimmed in carpet, and they use DynAudio separates in the doors. Dynamat is used in the doors and rear.
The sound is SO much better and there is full integration with the command system
I can post pics next month of the install
Paul
prsmith777 is offline   Reply With Quote
Old 04-11-2004, 11:39 AM   #6
Super Moderator
amdeutsch's Avatar
Paul
If they mess with your command in a way you describe you just lost the warranty on it. I would hope for your sake that they themselves would then cover the remaining warranty.
__________________
Old 04-11-2004, 11:51 AM   #7
You have a good point about the warranty. I will check into exactly what is done to the unit and what the warranty issues are before going ahead.
PAul
Old 04-11-2004, 05:40 PM   #8
Drives: 2003 SL500
Hey Paul we all look forward to see those pictures of the install next month or sooner. Dont forget.
__________________
drsarb
Bay Area, CA
Mods:
Brabus Quad Exhaust
Stereo Upgrade:
Focal 165 w3 Utopia
Old 04-11-2004, 08:20 PM   #9
Modifying the Comand system would most likely void the warranty as Mercedes never liked anyone to put ANY aftermarket parts on their cars.
I was sitting on a SL55 with Bose system the other day and I have to say the sound quality on that car is pretty okay for a stock system. If you guys are not happy with that system, I am not sure whether you can improve a lot just by changing the speakers, adding a sub and amp.
If the Comand system is not "that" important to you, I would suggest you guys to change the headunit as well. Remember, everything comes from the "head".
For speakers: Focal ALL THE WAY!
Harris is offline   Reply With Quote
Old 04-21-2004, 11:10 AM   #10
Here's an update on the upgrade:
Talked at length with the installer. The command modification is a software only mod and therefore wouldnt be a warranty issue. If any problems arise, the command could be reset to baseline at any dealer. Of course this would then erase the mods and you would have to have it redone.
However, in talking with the installer, he was not completely happy with the mod and thinks it wasnt done right. The issue is the frequency of the crossovers that MB uses. It is at 200, which is not a usable frequency for aftermarket equipment. The signal out of the command can be combined and then re-crossovered at better frequencies without messing with the command. He thinks this can be done without signal degradation.
Also, of interest, is something he has noticed that MB has done to discourage upgrades on the system. The command, for no apparent reason other than to screw with people, takes the right signal out of the command and flips the phase 180 degrees. The amp then flips the signal back 180 degrees so that sound quality is returned to normal. If you were unaware of this and added an new amp, then the right speakers would be 180 out of phase and sound would surely suck. Thanks MB.
I am going to go for it next week, probably.
Paul
Old 04-21-2004, 12:33 PM   #11
Drives: C32, 2003 -sold
Bose speaker polarities
I noticed the speaker wiring anonmally on the 2003 Mb C32 Bose wiring diagram. It shows the rear speaker polarities reversed from the front speakers. It seems very odd.
m444 is offline   Reply With Quote
Old 06-02-2004, 01:36 PM   #12
Drives: 2003 SL500
Here is the upgrade;
http://forums.mbworld.org/forums/sho...0&pagenumber=3
Enjoy!
__________________
drsarb
Bay Area, CA
Mods:
Brabus Quad Exhaust
Stereo Upgrade:
Focal 165 w3 Utopia
Old 06-05-2004, 08:51 AM   #13
hehehe
I have to admit: that's a pretty clever idea to flip the phase. I commend Mercedes-Benz on that basis.
By the way, I'm a big fan of Bose AND Focal ... so I really can't say which I like better. They're both superb.
MeeM is offline   Reply With Quote
Tags
aftermarket, ar3a, bose, c32, comand, custom, fx35, install, mb, mercedes, out, phase, radio, receiver, speaker, speakers, upgrade
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
