B Class Interior Lights removal
Old 01-13-2015, 04:42 PM
b250's Avatar
B250-W246
Guys
Has any B class owners have replaced their interior (rear door lights)? the one above the rear doors??
i have trouble trying to remove the cover so that i can changed the bulb to SMDs.
Regards
B250
Old 01-23-2015, 02:10 AM
mykylebb's Avatar
W246 B250
Originally Posted by b250
Guys
Regards
B250
I replaced all interior lights to T10 LED, you need to remove the upper handle above the rear door to release the lights bulbs, there are 2 covers at the side of the handle and you need to un-clip it first. Then you will find it is easy to release the handle and find the light bulb.
Old 01-25-2015, 04:30 PM
b250's Avatar
B250-W246
thanks mate. i tried plying out the two clips to access the screws to the handle as you mentioned but could not get the clips out and i am afraid of breaking it. do you have pictures how to remove this clips??. appreciate your help.
B250
Old 01-25-2015, 09:40 PM
mykylebb's Avatar
W246 B250
B250
Hi, I think a small but flat screwdriver in a short edge and may help to pull the clip out.
Old 01-26-2015, 04:13 PM
b250's Avatar
B250-W246
many thanks, will try again. BTW, did you changed the two lights under the Rear view mirror, if so how to you do it?. hope you don't mind sharing
Old 01-26-2015, 09:09 PM
mykylebb's Avatar
W246 B250
I didn't change that one, it is LED from factory.
Quick Reply: B Class Interior Lights removal
