Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > B-Class (W245)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
B-Class (W245) Discuss the new B-Class MPV: B200 Turbo, B200 CDI, B180 CDI, B150, B170, B200
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-22-2010, 03:06 PM   #1
Drives: 220cdi
B200 HID Install
Flickr problem was solved with a 4700uf 16v capacitor
Click the image to open in full size.
Long leg is positive, short one is negative.
The long one, has to be connected to the positive (red or blue) cable of the signal cable of the hid bulb. The short leg, has to be connected to the black cable of the signal cable of the bulb.
Here's a pic of the cable i'm talking about.
If it's not well connected, it will get very hot, and start releasing some smoke...turn off lights. If nothing happens, it's ok. U have to get some electrical tape on it, to protect it.
Well, the pics of the b-class.
Byee
To remove this ad, register today or login if you already are registered!
Pit_69 is offline   Reply With Quote
Old 01-18-2011, 05:19 AM   #2
Drives: B200
firstly, I got the Kaixen Xenon Light System... will this work?
can you explain the 4700uf 16v capacitor abit more... i am confused...
do you need photos of my HID Unit?
Leetino is offline   Reply With Quote
Old 02-10-2011, 01:49 PM   #3
I have just installed my H7 Xenon Hid Kit (Chinese Kit), and everything worked fine without need of adjustments.
That means that I just pluged the HID kit and everything worked, no sign of Light failure in the Cluster.
Maybe my kit was different from yours, but the fact is that it worked like a charm!
Jema_dc is offline   Reply With Quote
Tags
16v, 4700uf, africa, b200, capacitors, cdi, hid, install, installing, kit, kits, mercedes, south, turn, w245
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
