Sign in using an external account
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C250 Coupe
Race Chip Pro fine tuning
#2 |
Drives: C250 Coupe
Soo, some more detailed results. Stock vs. Race Chip Pro
Same day and time, same place, drive in S mode, ESP on Dynolicious setup: Rollout = 0 Trigger = 0,10G Ride setup: Weight = 1700kg Drivetrain loss = 20% I made 3-4 runs for every setup, below you'll find the best times for each setting. You can find what the chip settings are about in an attached image in my previous post. Chip setting; 0-60km/h time; 0-100km/h time; G value; HP value; no chip; 4,25; 8,41; 0,52; 199; C-0; 4,17; 8,19; 0,54; 203; C-1; 4,20; 8,21; 0,56; 207; E-0; 4,22; 8,22; 0,56; 205; D-1; 4,13; 8,24; 0,56; 201; 4-C; 4,28; 8,41; 0,56; 198; 4-0; 4,29; 8,45; 0,56; 201; This all means that there is no perfect solution, and putting the settings up too high will even result in worse power. I'm set to D-1 now. Attached you can find the graphs comparing stock vs one of D-1 runs. You may see the difference. The D-1 curve is smoother. So far I cannot say that i'm satisfied with the purchase. If someone has a better experience - please share. Next time I will post results with BMS Intake + Race Chip Pro. Last edited by tjk; 05-12-2012 at 01:30 AM. |
#3 |
Drives: 2012 C250 Sports Sedan, 2006 AMG E55
You did a 8 second 0-100km ? You sure your driving her right. Thats a toyota corrola time there. That chip is crap than, there is no way you shouldnt see some improvement in that 100km time.
#4 |
Drives: C250 Coupe
Well, this all is timed on an iphone, so there is no way it gets even to the stock 7,2 time.
#5 |
Drives: C250 Coupe
with power break, by the way, I can do 5,8 secs to 100km/h
#6 | |
Super Moderator
Drives: C230K SS, C250 Coupe, ///M5, GT-R Black Edition
Quote:
__________________
-Phil
| Tags |
| boost, c250, chip, coupe, dial, forum, improvement, instruction, power, pro, race, racechip, racechipde, remap, rpm, settings |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
