Can somebody help me regarding lowered my C300 Coupe 2017
C 300 coupe 2017 (C205)
Do I need front light adjustment after lowering my C 300 Coupe 2017 with H&R lowering springs? And do I need alignment also?
Thankyou.
Thankyou.
Generally you do it after you have it lowered. I also get it done about a week or two after I lower my cars to let the suspension "settle." Some people say you don't need to do this, but almost every time I had my car lowered, it always seems to be slightly lower a week later than the day after for some reason.
The only real way to tell if your car needs an alignment is to actually check the alignment first to see if its in spec. Some shops do the check for free if you need it, they charge you for it, if you don't then you drive off.
