brake lights blow fuse!!!! HELP
1998 C230 5-a
When I step on the brakes th fuse for the brake lights AND the instruments (number 19) goes and causes the radiator fan to run continuously while the motor is running. This is ugly. The rear running lights work, but the rear signals and emergency flashers do not. Is this a common problem?
I disconnected the middle/third brake light and fuse still blows.
I can drive with hand signals, but it is not safe.
HELP
HELP
