c280 Trunk locked
Old 07-04-2008, 01:17 AM
Mitchell_NY's Avatar
c280 1998, 2002 C32, 2000 Ford Excursion
c280 Trunk locked
Hey, I have posted on some of the other mercedes benz site trying to get this problem fixed. I have a 1998 c280 mercedes benz. all Of a sudden about 2 months ago, the windows, wipers, directionals ad the trunk all stopped working. I can get the drivers side window to go up and down with the key. The trunk is locked and will not open even with the manual key. I have been told to replace the k40 relay. i did that and no luck, no results whatsoever. Anyone have any ideas on what to do? please help me.
Old 07-13-2008, 03:03 AM
bonawitz07's Avatar
1997 Mercedes C280
I know that since the battery is in the trunk you may not know but is the battery itself dead? I had the same problems after leaving the lights on overnight and had to call the mercedes dealership who easily helped over the phone. If you need more help with the steps, I'd gladly respond.
Old 07-13-2008, 06:00 PM
whatup?'s Avatar
red bicycle
Is the K40 relay the same as the Combination Relay (Part # 201 821 02 47)? The intermittent wipers and rear defroster have more or less quit on my 1996 C220, and I've narrowed it down to the Combination Relay after some internet research. Everything else is working fine on the car.
Old 08-14-2009, 02:28 AM
tony_taweel's Avatar
1998 Mercedes C280
hi im new to the forums and i was also doing some internet research your problem almost sounds the exact same as mine my central locking system is down i have to lock and unlock my car using my key to put the windows down then lock then put them back up its a hassle. The person who owned it before me had mixed up the fuses and i rearranged them back following the diagram a few weeks ago i hope i didnt do it wrong because i cant get into my trunk at all not even with the key please anything will help.
Old 08-14-2009, 06:30 AM
!!!!!NJ Drive's Avatar
to those who cant open the trunk with the blade key,make sure your doing it right...put key in, turn, then push in.
Quick Reply: c280 Trunk locked
