Engine Compartment Diagram
Old 02-20-2011, 09:34 PM
phyberlink's Avatar
1996 C-280 2003 BMW 330Ci Conv
Hi, I am trying to locate the MAF unit, under the hood, is there a 1996 C-280 diagram of parts location ? I just want to know where it is located. Thanks.
Old 02-20-2011, 11:55 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Part 80:
Old 02-25-2016, 06:20 AM
wanracer86's Avatar
C200
What is the name of part no.93?
Old 02-25-2016, 01:37 PM
ptcruiser's Avatar
C230
Top upper right of the diagram is the air box, next is the air filter, and third item is the MAF,
It has a little oval plate on the side with two Torex head screws. Remove the screws, gently twist out the sensor after removing the screws, remove the main tube that the sensor was connected to, and it's done. 2 minute job if your slow :-)
Old 02-25-2016, 01:40 PM
ptcruiser's Avatar
C230
93 is either the alternator or the A/C pump.
The one your looking for is No. 80 MAF
Quick Reply: Engine Compartment Diagram
