Sign in using an external account
| C-Class (W202) 1995-2000: C 200 CDI, C 220 CDI, C 270 CDI, C 180, C 200 K,C 230 K, C 220, C230, C 280 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 98 C280 Sport
W202 Fuel Problem
#2 |
Drives: 98 Black C43 , 00' C230K , 91 420SEL , 08' ML320 CDI
Crank position sensor ?
__________________
No engine , no badge
#3 |
Nope. That went out a couple years ago. Slightly different. I've found out its the sender on one side of the tank or tube between the two senders thats plugged. Thanks for the input!
#4 |
Drives: w202
My W202 have a small leak under the fuel tank on the left side in front of the rear left wheel. There is petrol smell especially in the morning. Please advise what part of the fuel tank is leaking
#5 |
On passenger side in front of left wheel is where the fuel filter, fuel pump, and hoses connecting the tank to each are located.
#6 |
Drives: chevrolet z-71
Please oooh please explain where this so called sender and cross over tube are located!!!!!! And what steps you took to fix the problem!!! I have a 96 c280 with almost the same described problems! I've changed pump,filter, valve job done(head rebuilt), and numerous other things. My lil beast has 195k on it and I'm pretty sure that the items you described have never been checked. Thanks
| Tags |
| 95, 98, c280, drive, fuel, gas, half, issue, mercedes, problem, ran, runing, runs, solenoid, sport, start, tank |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
