Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W202)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-29-2012, 11:44 AM   #1
Drives: W202 C180 1993
1993 W202 C180 A/C problems help needed
Dear all
the PO of my car messed up the AC system's wiring pretty bad, summers are starting so i thought I should have a go and got a wiring diagram for the AC system for a 97 W202. That was all I could find :s
My 202 is a 1993 model with 1800cc and 5sp manual transmission. I need the wiring diagram for the Air conditioning system. I don't know what is the system is called exactly but the controls have two *****, two dials and four bottons (REHEAT, EC, REST, VENT).
I'd really appreciate if someone could get me a wiring diagram for my car.. chassis no: WDB2020182F017766
thanks
To remove this ad, register today or login if you already are registered!
syncview is offline   Reply With Quote
Old 05-06-2012, 01:16 AM   #2
So i've got all my wiring corrected up and most of the things are working now.
I found out that the PO has REMOVED the evaporator temperature sensor for a reason that only GOD knows.
Anyways, i've ordered the part (part#210 830 07 72) and I was testing in the time being - fixed a evap sensor out of a corolla the, compressor runs but doesn't trip making things ICY. anyways, I can't seem to make the vents work properly, they work on vacuum and also the heater isn't working (i have replaced the duo valve and installed new coolant pipes). When I turn the dials to the heater, shouldn't it turn the compressor off and start blowing in warm air? or am I getting it wrong?
I have checked the vacuum switchover valve (y11/3) manually, it has four solenoids inside and all are working, when engine is running the vents and flaps actuated by the vacuum are working. but when I connect the valve and the CCU, the vacuum switchover valve doesn't seem to receive any input from the controller? is my CCU bad? :s
Old 05-31-2012, 07:49 PM   #3
Drives: 2001 cl 600
hey bro i have a 1997 c280 and we cant get the center vents to work on my a/c also sometimes the a/c doesnt come on, i turn off the key and try again most times it comes on sometimes it doesnt. any ideas or help is appreciated.
nightmare cl600 is offline   Reply With Quote
Tags
210830, 97, ac, air, c180, c280, car, conditioner, diagram, install, messes, problem, w202, wire, wiring, working
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
