Having issue with Koni Installation and input is greatly appreciated
Old 08-01-2014, 08:00 PM
Demode1204's Avatar
1996 C36
I recently had a shop install my vogtland springs and koni shocks and upon picking it up and driving around the block noticed a rattling sound coming from the interior. When I opened the hood I noticed the top thread of the shocks has major play and does not tighten to the body. You can actually push the car downward and the threaded portion of the shock remains in place and does not move with the car. Doesn't this defeat the purpose of the shock?
Old 08-01-2014, 09:00 PM
Former Vendor of MBWorld
Need4Speed's Avatar
2018 C63S
I would recommend you take it back to them ASAP and have them fix that.
It seems likely a bad installation IMO
Old 08-02-2014, 12:24 AM
Super B's Avatar
'97 c36
+1 I'm pretty sure they left no.4 out (rubber spacer)
Attached Thumbnails Having issue with Koni Installation and input is greatly appreciated-image-1498832381.jpg
Old 08-02-2014, 09:36 AM
Demode1204's Avatar
1996 C36
I think you are correct my friend. I know the Koni shocks didn't bring this is this something that should have been recycled from the stock shocks?
Old 08-02-2014, 11:37 AM
nhmercracer's Avatar
The incompetence of some shops is amazing.
Old 08-02-2014, 01:18 PM
Super B's Avatar
'97 c36
Correct. If you look at the diagram koni gives you everything that has a square around the number of the part is re-used from your original shock (two rubber spacers, the foam bump stop and the dust boot that is drilled to enlarge the center hole)
I simply cannot believe they sent your car out of the shop like this. I'd find a new shop. Shocks are one of the easiest jobs on our 202 cars. If they cannot do this task and even worse could not tell something was wrong when tightening down the top shock nuts. I would have serious concerns about their wrenching ability.
Old 08-05-2014, 09:32 AM
Demode1204's Avatar
1996 C36
I never took it out of the shop I Immediately pulled it right back in. To the mechanics defense Koni did not provide that diagram you where kind enough to share however IMHO (and maybe i'm wrong) it should have been common sense.
Everything is good to go now aside from the ride height. I'll create another thread in regards to that issue as I'd like some input on how to correct.
Thanks for the help guys!!!
Old 08-06-2014, 03:27 PM
Super B's Avatar
'97 c36
IMHO (and maybe i'm wrong) it should have been common sense. Everything is good to go now aside from the ride height.
Agreed, but hey glad you got your ride right.
Quick Reply: Having issue with Koni Installation and input is greatly appreciated
