transmission problems
1999 c280
my 99 c280 sport has started shifting with a jerky motion it takes off from a start in the mornings then throws us back in the seat like it just down shifted.sometimes when we come to a stop sign it down shifts very hard into a lower gear .iv'e read you can't check the fluid level is this correct?also any help on why the trans.shifts funny sometimes? thanks
You can check the fluid level with the proper equipment. You'll need the Dipstick Tool. I also recommend replacing the filler cap and locking pin.
Transmission Dipstick
And,
Filler Cap Locking Pin
And also,
Transmission Filler Cap
And,
And also,
Before going further, have you had it up to see if there is any tranny fluid leaking.
If not, it's a different problem.
To the things suggested by Autohaus, you should add an
http://www.ebay.com/itm/Non-Contact-Temperature-Gun-IR-Laser-Infrared-Digital-Thermometer-Sight-Handheld-/131195576458?pt=LH_DefaultDomain_0&hash=item1e8bdda08a
Available on Ebay for about $12.00
I would try resetting the 722.6 Transmission settings and see if it still does that jerking motion. If and possibly it still does, I would do a Trans service & flush all the way back to the converter. And if that doesn't fix your problem, then your transmission might be going out, but I say reset & flush.
