Cleaned MAF, now the car just dies
Mercedes C180 W202
I pulled the MAF out yesterday to spray it with a cleaning solution on it. After i did that and reinstalled it, I started the car up and went to drive it and it went into that "limp home mode" where it will just idle and any throttle at all just causes the car to stall, well lets put it this way it won't take throttle at all. So then I tried to disconnect the MAF but then the car would just die. Did I ruin the MAF by cleaning it? What do you think guys? Appriciate all the help I can get!
Mercedes C180 W202
I used an electronic cleaner, which I bought at the local home depot store.
00 C200 & 00 C55 & 06 SLK55
Many things could cause thi kind of power lose,
"CPS/TPS/TB/MAF/spark plugs/coils/fuel pump/fuel filter"
which M/Y of your C180..?, do you have a chance to diagnostic the car..??, codes will helps a lot to narrow the issue..!
ZAYED,,
ZAYED,,
