Clarification: Will 18inch AMG Monoblocks work on my C280?
1999 C280
Hi Guys,
I've searching and found some worrying posts about anything bigger than stock will give a check engine light. Is this true?
I also saw worry abou rubbing in the back. Will I have any issues when I install these? And what size tires will be needed? I have the staggered 18x8 and 18x9 setup.
Can someone help a brother out? Will this work with the stock lugs too? I saw someone mention spacing in the rear. Do I need rear spacers?? HELP! LOL
Cheers!
Cheers!
00 C200 & 00 C55 & 06 SLK55
Yeah, they will work,
you can go with fronts:- 225/40/18, rears:- 255/35/18,
can't confirm about lug bolts, it depends of the off-set & bolts length..!,,
i may assume front bolts will fit, but not sure about rears, you may need longer length..!??!
ZAYED,,
ZAYED,,
