rattling noise, think its the belt tensioner
w202 1998 c230
my car is making a rattling noise when i first give it gas from idle and when i first put it into gear while idling it makes the same sound, just had the tensioner pulley replaced as well as my motor mounts
If it does wobble, it could be that the pulley is scraping on the water pump as it's rotating.
Try tightening the 4 pulley bolts, and if that doesn't work, it could be the water pump shaft bearing is worn out. You would need to replace it, but not a big deal, except for the belt which can be a *****.
https://video.search.yahoo.com/video...&hsimp=yhs-001
Glad you found it...They can rattle, but was it working?
Anyway, if you want to save some bucks to fix it, you can buy a used compressor on Ebay for about $60.00, and just switch over the parts.
A lot cheaper than http://www.ecstuning.com/ES1602590/
Good luck
Good luck
