ABS Ligth ON/OFF
ABS Ligth ON/OFF
Hi, in my C280 1996 ligth ABS is on and off, the abs system not work, I clean sensor, but nothing happens.
The scanner send presion problem in ABS pump, It is reparable?
I look in http://www.ebay.com/itm/ABS-PUMP-ASSEMBLY-MERCEDES-BENZ-W202-C-CLASS-C220-C230-C280-1996-1997-1998-OEM-/351115711040?hash=item51c0209240&vxp=mtr
Thank
Thank
The pump itself is probably repairable. But I would advise replacing the pump with possibly a new one to make sure it won't cause problems in the near future. If the cost of the repair would be under $100 I would say that it is worth it but you would need to find a place that sources all the sub-parts for it to be fixed. I would not imagine that the repair costs would be as low as that and I think that getting a used one from eBay would be a good choice.
jmb
jmb
