INSTURMENT CLUSTER PROBLEM
Hello friends i have c202 c280 gasoline engine MB
i have a problem with the insturmet cluster the problem is the gauges (neeedels) like thermometer ,rpm meter , fuel ,and speed doesnt work they are stuck in the bottom (on zero) i trid to replace to insturment and it didnt succsed i checked fuses and nothing i really need help
if someone had this problem or know how to fix that plz help me
thank you.
also the lcd monitors doesnt work
but the light on the insturment works .
thank you .
thank you.
thank you .
W202 C280 ('95)
I've got the same issue. In searching forums I came across a fix by member "doin12volt" at benzworld.org he says it is NOT electrical. Check it out; scroll until you find him as he's had same issue as we do.
http://www.benzworld.org/forums/w202...ix-read-3.html
