Rough idle 1998 C230
Old 08-30-2015, 02:06 PM
Doug427's Avatar
2006 E55 AMG, 2018 Audi Q7, 2005 Porsche Boxster S, 1930 Model A Hot Rod, 744HP 1965 Shelby Cobra
My 1998 C230 runs very smoothly when at any speed above idle, but idles fairly roughly, especially in drive when the RPM's are lower. No check engine light is on. Any common problem areas I should look at? I did remove and clean the throttle body (it was filthy). I also removed and sprayed the MAF sensor, which some around here where I live have told me is not usually a good idea. Too late, it's done. The cleaning of the throttle body did make a very small change for the better.
I have looked for vacuum leaks, but haven't seen anything obvious. What's the best trick for trying to pick up a vacuum leak that you may not have noticed?
Any other ideas would be greatly appreciated.
Thanks!
Old 09-05-2015, 02:20 AM
SlickVick's Avatar
'01 E55 AMG
Do you have a check engine light or no?
Old 09-06-2015, 07:50 PM
Doug427's Avatar
No check engine light. Car runs smooth except at idle. Not too bad in Park or Neutral, very rough in drive at idle.
Old 10-13-2015, 03:46 PM
PJmak's Avatar
I have exactly the same thing on my 00 c280.
I got a check engine light for egr valve p0400
Im planning to look into that and also i heard ovp relay and voltage regulator could cause this.
any electrical issues with the car?
Old 10-14-2015, 04:14 PM
PJmak's Avatar
Take your egr valve off. Its got a sensor attached to it and three rubber lines for vacuum. I had one line that was really bad(going into the intake manifold and around 4-5" long)
Another one that connects the sensor to the egr valve was not as bad but i replaced it too.
My idle improved dramatically but it still shakes. I think I might have bad engine mounts
Old 10-15-2015, 10:56 PM
Doug427's Avatar
Just to report back. I changed both engine mounts and the trans mounts. Now smooth as silk. I've never seen a car before so sensitive to engine mounts. Live and learn, I guess.
Old 12-21-2018, 07:15 AM
Viktori's Avatar
C63 AMG W204
wrong thread
Quick Reply: Rough idle 1998 C230
