Broken plastic tube (Please Help)
Old 01-11-2016, 03:55 AM
lehuyvu's Avatar
I was trying to remove the windshield wiper motor and accidentally broke the plastic tube (first picture below). I am not sure what is the function of that tube. Can anyone please let me know what is that tube used for so I can try to buy replacement. Thank you very much.
Old 01-11-2016, 11:57 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
I would suggest that you get a free subscription to MB EPC which with your repeat your search will help define the part correctly
Old 01-11-2016, 06:19 PM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
I could be wrong, but i think this line for center A/C vents, which control the temp. of evaporator..!!
ZAYED,,
Old 01-12-2016, 02:15 PM
vinceC's Avatar
2014 ML350 4Matic
I'm not sure of the function but you can just cut the fitting off and splice the two lines together with some vacuum hose.
Old 01-15-2016, 04:40 AM
lehuyvu's Avatar
VinceC, your solution worked perfectly. Thank you very much.
Quick Reply: Broken plastic tube (Please Help)
