C230 doors
Old 03-13-2016, 09:57 AM
hs545's Avatar
1999 C230 Kompressor
C230 doors
Have a 1999 C230K, both drivers side doors are rusted. I have access to 1997 C230 that is being parted out with good doors. Does anyone know if the doors are the same. Will I be able to swap the door handles and interior panels?
thanks!
Old 03-14-2016, 05:19 PM
Russell Ormerod's Avatar
not a merc
Should work
Old 03-26-2016, 11:34 AM
PJmak's Avatar
Pre updated w202 doors will fit but they are not designed to fit an airbag so you wont be able to fit your airbag on it
I am parting a 99 c43. Let me know if you want doors I ha e all four. I am in Nor. Cal.
Old 03-27-2016, 10:21 AM
hs545's Avatar
All I need is the sheet metal and was planning to remove the entire interior door panel and move it the older door.
Are you saying the interior panel air bag assembly won't fit? I assume the 99 C43 has the same doors. What color are your doors.
Old 03-27-2016, 10:34 AM
not a merc
Airbags are riveted to the sheet metal part.
Old 03-27-2016, 01:57 PM
PJmak's Avatar
The c43 is 040 black
Quick Reply: C230 doors
