1999 c230k shaking
Old 04-12-2016, 02:18 AM
Ali Ramazhan's Avatar
1999 mercedes c230k
1999 c230k shaking
Hi, i have 1999 mercedes-benz c230 kompressor with about 160,000 miles and i have a lot of shaking when i put my car in Drive. When i am in park or reverse its quiet. Also when the car warms up some of the shaking goes away or when i put in more gas i notice a little more difference in the shaking for a couple of days but still is bad. I put in regular fuel for about 3 to 4 weeks and switched to premuim which did cause the car to run better i also changed spark plugs maf sensor and checked for air leaks but nothing can someone help me ?thanks!
Old 04-12-2016, 07:25 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Sounds like something is retarding\advancing the spark---I'd check the throttle body system---the problem is that you have to have the diagnostics to to that---some things just can't be fixed at home!!
Old 06-08-2016, 10:45 PM
outlawslaw1's Avatar
1999 C230 Kompressor/1993 300E
My 99 230 K says PREMIUM FUEL ONLY right on it?
Quick Reply: 1999 c230k shaking
