NEED 1999 c280 vacuum diagram
1999 c280 w202
Hello,
I have a problem finding a vacuum diagram for 1999 c280. I found a line loose. drivers side, parallel to egr valve line that connects to the block near the valve pan. this hose is approx. 7 to 9 inches long.
Maybe if you post a picture of the end that you know is connected correctly, then, with a little luck, perhaps someone will post a picture of the other end for you.
Also, you might look hard for a "hoseless" hose connector or hard vacuum line (in the 9" radius from the good connection) that's in need of a hose.
But the vacuum diagram would definitely interest a LOT of people if it were available.
