w202 Gauge cluster illumination problem
Old 09-10-2016, 09:12 AM
jm230's Avatar
C230 Kompressor
Hello. I have 1996 mercedes benz c230 kompressor. The gauge cluster lights suddenly stopped working. Clock, mileage- and temperaturemeter works fine as well as the warning lights. I've tried to change the bulbs, lightswitch and battery. Anyone else had the same problem?
Old 09-11-2016, 07:15 PM
mickey13's Avatar
1999 AMG C43
Did you check the fuses? You didn't mention it.
Old 09-12-2016, 11:11 AM
jm230's Avatar
C230 Kompressor
All fuses are ok.
Old 10-06-2016, 11:18 AM
jm230's Avatar
C230 Kompressor
I changed whole instrument cluster still no illumination.
Old 10-06-2016, 02:32 PM
Shadedmoon's Avatar
Mercedes C230 1997 W202
Perhaps too easy but did you by any chance turn the light switch left of the cluster? On mine the center position does not give illumination in the cluster while the full right position does. This however means headlights stay on even if the key is drawn out of the ignition. So I need to manually turn the switch each day.
Old 10-31-2016, 03:41 PM
jm230's Avatar
C230 Kompressor
Where I can found w202 instrument cluster wiring diagram?
Old 03-20-2017, 12:56 PM
jm230's Avatar
C230 Kompressor
I have not yet found a solution
One thing that I noticed is that the instrument cluster lights flash when I turn on the lights
Quick Reply: w202 Gauge cluster illumination problem
