Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W202)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-08-2004, 05:31 PM   #26
Rincewind's Avatar
Drives: 1998 C230
doug could u take pics on where u put the hose in the car to fill'er up with freon
To remove this ad, register today or login if you already are registered!
__________________
1998 C230 Brilliant Silver
K&N Air Filter
OEM Mercedes Clear Corners (Bosch)
OEM Mercedes All-Season Rubber Floormats
OEM Mercedes Avantgarde Grill
OEM Mercedes Coin Tray
Coming soon: Super Sprint Headers, AMG W202 Exhaust, AMG 18x8 Monoblocks
"I like cars the same way how I like my girls; fast and topless."
Rincewind is offline   Reply With Quote
Old 05-08-2004, 07:28 PM   #27
Drives: C220
Quote:
Originally posted by ahopeter
what the hell!?! i said freon and cil...something said i was wrong. huh!?! i guess thats what i get for believing a noob.
I was reffering to this post
http://forums.mbworld.org/forums/sho...threadid=66901
cil254 is offline   Reply With Quote
Old 05-09-2004, 12:57 AM   #28
pointman's Avatar
Drives: a car that can't do the throttle reset.
and i was referring to this post you are reading...check page one.
pointman is online now   Reply With Quote
Old 05-09-2004, 01:00 PM   #29
Drives: 2008 SLK-280
Send a message via AIM to DougandhisC280
I'd love to take a picture and help you but unfortunately Evosportworld won't let us post pictures anymore. I'll be on AIM most of the day so if you see me on there I'll explain it to you then.
DougandhisC280 is offline   Reply With Quote
Old 05-27-2010, 03:03 PM   #30
Drives: (06) c55 and (06) ML500
ac recharge diagram c36?
joe chebeir is offline   Reply With Quote
Old 05-27-2010, 10:55 PM   #31
Drives: 2000 c230 Kompressor
since I recharged my system with a leak kit, it's been great! I assume I would have seen a leak by now (knock on wood that I won't). The pressure has remained fairly constant. Keep in mind that when you measure the pressure, it will vary depending on the temperature surrounding the port and also if the engine and compressor were just running. When a gas gets compressed enough, it becomes liquid. If that liquid warms up, it goes back to gas (which takes up more space) and the pressure will show an increased reading. Likewise, as the gas gets re-compressed, the pressure reading will be lower. I know this seems kind of counter-intuitive, but if I remember my chemistry, then this is how it goes.
AcousticplayerJ is offline   Reply With Quote
Old 04-15-2012, 10:10 PM   #32
Drives: wdbjf55fxtj020203
Help. Help, Help..this is the srangest problem, ONE SIDE IS BLOWING ICE COLD the other side is warm,,, the driver side staying warm no matter what the setting is,,.Not sure where to start,, any idea? hints? etc,, OHLORD, wher are you?
Help
not
tmounib is offline   Reply With Quote
Old 07-13-2012, 06:52 PM   #33
Drives: 2004 CLK 320
04 CLK 320
The issue i'm having is when running the AC, it is super cold on the right side vents and almost warm on the left side. I've tried adjusting vents, reset the system but it continues to do this. Any ideas ?
AndyZim is offline   Reply With Quote
Old 07-25-2012, 09:00 PM   #34
Drives: 1999 E320
Warm on one side while cold on the other side may be a stuck duo-valve. I just fixed this problem on my daughter's 96 C220 by cleaning the solenoid plungers in the duo-valve. They had crud built up on them causing the one that controls the passenger side heat to stick open. It was only about a 20-minute job.
Geraldius is offline   Reply With Quote
Old 09-06-2012, 10:11 PM   #35
Drives: 1998 C 230 mercedes
where and what is the duo valve??
uncle1etoe is offline   Reply With Quote
Old 09-17-2012, 09:44 PM   #36
Drives: 1999 E320
Quote:
It controls the flow of hot water from the cooling system through the heater.
It is located in the top-rear engine compartment on the passenger side under the big plastic cover.
Do a search of this or other MB forums for duo valve.
Tags
1999, 2000, ac, air, blowing, c230, c280, car, cold, fill, freon, ml430, put, refrigerant, slk280, stop
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
