Water pump replacement cost
05 C240 wagon, 01 E320, 94 Miata (supercharged sold), 01 SLK 320
95 C280 with 88km...
Tapping noise can be heard from water pump for the last few weeks. Finally, yesterday, I saw some clear, sticky fluid dripping through the hole on the bottom oil pan cover. Took the cover off and found the dripping is from the water pump area.
1. How much does it cost to have the water pump replaced?
2. How can I find out how much coolant in the engine? The overflow reservoir shows full.
3. Okay to drive the car to the shop (15 mins drive), as long as I keep my eyes on the temp gauge?
DB
DB
DB
DB
guessing if the temp is normal, you should be ok for a very short distance. It
sounds like you found the problem right in time. Let's see what others can
share on this topic. Good luck.
I forgot to mention
You only have about 4 miles of driving at approximately 40-45mph before
the engine's coolant temp is in the normal range.
Originally Posted by narci
I just changed mine. It's harder then you think. You have to move the power steering res and stuff. about a 4-6 hour job.
Car runs like new after i got mine changed.
Originally Posted by trbo2nr
The part itself is around $230 and shouldn't be too difficult to do. I'm only
Thanks for the input
DB
