Where to get front bolts for W202 Camber Adj.
Just had alignment after lowering and the left front camber is -1.8 degrees and right front is -1.3 degrees. Both out of spec per the alignment shop.
Am I correct that there are new bolts that can be installed to correct this? I would need part numbers and where to buy as the local dealership has NO Clue (their main line is Buick and they only have one MB tech). Eibach does not make a set for this car, already tried.
1 Post
2008 SLK-280
The bolts are almost not worth installing because they barely adjust it. I have some that I will ship you for $20 plus shipping if you'd like. Still new in packages. I have 4 of them. I have just gotten used to my inner tires wearing a little sooner than the outside. I probably lose about 2000 miles on each set of tires.
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
As Doug said, they don't do much, but the small amount that they do move does make a difference.
20" Camber adjustment
25" Caster adjustment
Part number: 202-330-01-18
all of them are the same.
