DIY Throttle Calibration?
Old 09-01-2006, 11:17 PM
Admin Alumni
MB-BOB's Avatar
See Garage
This sure beats disconnecting the battery, or other resets discussed here.
Old 09-02-2006, 12:30 AM
Super Moderator Alumni
ScottW911's Avatar
a C32 AMG & S-Works Tarmac
I've done this many times on my C32. I have never experienced any problems and, geez, does the car ever feel nice afterwards. It just resets the throttle adaptations to the original factory settings. After about 40 accelerations, your ECU is re-trained to your driving style. Just reset again and have fun. On my C32, when I jump on it after a reset, the ESP light stays on for several hundred yards. Cool.
Old 09-02-2006, 09:11 PM
slkfans's Avatar
Thanks for posting this, tried on SLK R171, it works....
Old 09-02-2006, 09:31 PM
Tangerine's Avatar
Is @ Home
good info, sure is better then disconnecting the battery and setting all the other settings back. does this only work for autos or can it work for manuals?
Old 02-09-2007, 09:30 PM
scottw's Avatar
2007 C230 Sport manual
Can Super Moderator, or anyone else, advise if this ECU procedure works for us manual drivers? Jeesh
Old 02-09-2007, 09:32 PM
rlee02135's Avatar
2004 C32 ///AMG
try it out...
Old 02-09-2007, 09:35 PM
  #32
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Originally Posted by rlee02135
try it out...
Old 02-09-2007, 10:53 PM
  #33
advans's Avatar
C55 ///AMG, 535xi
I remember reading somewhere that you dont even have to wait the two mins.
Old 02-10-2007, 08:03 AM
  #34
Drop-a-Daimler's Avatar
2006 C55 AMG, 2.8L Quattro, Softail Nostalgia 1550 (Stage III), Sporster (slammed)
I did it and it is nice.
But be advised, don't do it close to an emissions inspection. At least in VA. You need a couple of hundred miles of different style driving on a newer car before the emissions test can be completed. They plug into your ODBII connector and if you have just reset the data log then it comes back "Not Ready" -- not enough data captured to confirm the emissions are working properly. They told me to come back in a couple of weeks to try again. No charge at the time since it couldn't be done.
Old 02-10-2007, 10:38 AM
  #35
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Merge
Old 02-12-2007, 01:42 AM
  #36
Moon-Coupe's Avatar
'02 C230 Sport Coupe
Yes it does.
It made mine more responsive and more importantly, it made my shifting smoother by holding the rpms correctly during shifts.
I couldn't make a smooth shift in any gear before doing the reset.
I also heard the verification click in the dash 3 minutes after doing it.
Old 02-13-2007, 10:02 AM
  #37
John McLane's Avatar
Just got my first MB in the US, C 230K, and it failed to pass the inspection here in MA due to the same reason. I should wait another 500 miles until there is enough information to run the checklist.
Old 02-23-2007, 10:06 PM
  #38
kevblah's Avatar
E90 M3
Worked for me, didn't wait the 2 minutes.
Old 02-25-2007, 02:04 AM
  #39
Midnight Koop's Avatar
CL203
do you think if you reset the throttle periodically and purchase a sprint booster that the affects will be superimposed? or will the affects of a sprint booster for example replace the need of resetting the throttle because the response will be maximized?
Old 02-26-2007, 07:26 PM
  #40
ZAKON's Avatar
W203 M111.955 2.0 kompressor
I would like to know if this procedure can affect or reset any data on a "Tuned-reprogrammed" ECU.
Thank you in advance.
Old 02-27-2007, 01:47 AM
  #41
KleanC's Avatar
White C
Tried this and it didn't Work. .
Old 02-27-2007, 01:55 AM
  #42
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
can someone post pics step by step plz??
Old 02-27-2007, 03:06 AM
  #43
Moon-Coupe's Avatar
Post #3 has the 4 steps. Very simple procedure, no need for Pics.
Old 02-27-2007, 07:32 AM
  #44
ZAKON's Avatar
Please, i need an answer
Old 02-27-2007, 07:39 AM
  #45
topdaytrader's Avatar
Nice, I'll try it tonite.
Old 02-27-2007, 11:03 AM
  #46
ScottW911's Avatar
There are several threads on this subject, one being in the C32/C55 forum. No one seems to have had any ill effects from doing the ECU reset. Many C32 & C55 owners have "tuned" ECU's. Basically, you are dumping the owner adaptions from the memory. Nothing else. It will take about 40 accelerations to fully re-adapt to your style.
Old 02-27-2007, 11:12 AM
  #47
ZAKON's Avatar
Thumbs up
Thank you
I tried it today, my sprintbooster started to work again (as it was working on the first days after installation!) Superb!
Old 02-27-2007, 01:48 PM
  #48
ScottW911's Avatar
It's not that hard to do. Turn the key on so all the lights on the dash light up, mash the gas pedal and wait at least 5 seconds. Turn the key off and release the gas last.
You will not, most likey, notice any beep or indication that anything happend until you fire up and drive away. You should notice a more responsive car right away.
Old 02-27-2007, 01:51 PM
  #49
KIRA's Avatar
yea i feel my car response much better, i kinda confused because i can't hear any beep or clicking sound, anyway, i got it..
Old 02-27-2007, 01:56 PM
  #50
ScottW911's Avatar
Glad to hear it. Some people do this every day. I do mine every couple of weeks or so. It has helped minimize the transmission "jerk" common on the 2002 C32's. Oh yeah, it also is tremendous fun, after the reset, to drive.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: DIY Throttle Calibration?
