W203 Technical Service Bulletins
#54
for the W210 E320 folks, i've been offering to send folks most of the TSBs for
their model/year. they're PDFed linked but I stop the compilation at thousand
pages or so. they're more than just TSBs....in Alldata, they also have ancillary
links to their pics/diagrams/schematics so I pull up TSBs and a couple of linked
layers of DIY type info.
just email me and tell me year/model/engine. i'll get to it whenever..... for my
99 E320, I stopped it at 4k pages and it was about 72mbs, and took several
hours. that's why i limit it at 1k pages. i've figured out how to compile multiple
years at the same time so it should be easy for me to grab several yrs at a
time. i do this at work but let it run in the background or on spare computer.
the information contained give great insight into the workings of your car and
often answer those observations you may have made regarding annoyances,
ideosyncracies, etc
ideosyncracies, etc
#55
06 C230
Check this link for the latest MB TSB's, campaigns, Recalls...
http://alldata.com/tsb/Mercedes-Benz/index-post.html
#57
06 C230
Looks like Alldata moved the latest TSB's. The Alldata link does not work anymore...
Anybody knows where they went?
Thanks to Google's cache, I could get a copy of these latest TSB's. But this is only the list. I don't know where to get each detailed item:
Post Date Issue Date TSB Number Title
Tue, May 23, 2006 Thu, Feb 2, 2006 P-82-10-258B Lighting - Front Turn Signal Lamps are Inoperative
Wed, May 24, 2006 Wed, May 1, 2002 2005100013A Campaign - Auto Trans Control Module Reprogramming
Wed, May 24, 2006 Wed, May 1, 2002 2006030011C Campaign - ECM Update and or Air Injection Relay Replacement
Wed, May 24, 2006 Wed, May 1, 2002 2006040004 Campaign - Front Axle Carrier Bolt Sleeve Cleaning
Wed, May 24, 2006 Wed, May 1, 2002 2006050003 Campaign - Engine Control Unit Software Update
Wed, May 24, 2006 Wed, May 1, 2002 P-82-70-358 Cell Phone - Installation Instructions and Set Up
Wed, May 24, 2006 Wed, May 1, 2002 P-82-70-415 Cell Phone - Voice Control System Installation
Wed, May 24, 2006 Thu, May 9, 2002 P-94-20-05A Interior - Strong Acidic and or Putty Like and or Rancid Butter Odors
Tue, May 30, 2006 Sat, Apr 1, 2006 P-88-50-45 Accessories - Trunk Lid Valet Lock Retrofitting
Tue, May 30, 2006 Mon, May 1, 2006 S-15-40-58 Charging System - Voltage Regulator Testing and or Inspection
Tue, May 30, 2006 Thu, May 18, 2006 P-82-60-382A COMAND(R) - Wrong Radio Station Displayed and or Other Issues
Tue, May 30, 2006 Thu, May 18, 2006 2006030011D Campaign - Replace Secondary Air Injection Pump Relay
Tue, May 30, 2006 Mon, May 22, 2006 P-72-10-51A Body - Wind Noise and or Water Leak at Door Glass & Quarter Window
Tue, May 30, 2006 Mon, May 22, 2006 T-46-20-30C Steering - Fluid Leaks and or Noises and or Heavy Steering and or Looseness
Tue, May 30, 2006 Tue, May 23, 2006 P-68-50-50 Interior - Load Compartment Cover Sags On One Side
Tue, May 30, 2006 Tue, May 23, 2006 T-31-19-07C Accessories - Trailer Brake Controller Installation
Mon, Jun 5, 2006 Mon, Feb 27, 2006 P-32-22-18C Suspension - Knocking Noise and or Car Too Low Message and or DTC Set
Thu, Jun 8, 2006 Wed, May 24, 2006 P-54-30-171 Instruments - Inaccurate Outside Temperature Readings
Thu, Jun 8, 2006 Wed, May 24, 2006 P-68-50-51 Interior - Load Compartment Cover Drive Won't Switch OFF
Thu, Jun 8, 2006 Wed, May 24, 2006 T-91-60-93C Air Bag System - SRS Lamp ON and or DTC's 9200 and or 9210 Stored
Thu, Jun 8, 2006 Thu, May 25, 2006 P-72-12-61 Interior - Rear Door Window Blind Hook Broken
Thu, Jun 8, 2006 Fri, May 26, 2006 T-82-85-506 DVD COMAND(R) System - Head Unit Won't Turn ON
Thu, Jun 8, 2006 Fri, May 26, 2006 P-27-60-75 Auto Trans - Unsuccessful ECU Initial Start Up
Thu, Jun 8, 2006 Fri, May 26, 2006 P-82-85-447A DVD COMAND(R) System - Head Unit Won't Turn ON
Thu, Jun 8, 2006 Fri, May 26, 2006 T-27-60-76 Auto Trans - Unsuccessful ECU Initial Start Up
Thu, Jun 8, 2006 Tue, May 30, 2006 P-43-10-02 Brakes - Whistling Noise When Releasing Brake Pedal
Thu, Jun 8, 2006 Tue, May 30, 2006 P-82-10-376B Lighting - Xenon and or Bi-Xenon Headlamps Inoperative
Thu, Jun 8, 2006 Thu, Jun 1, 2006 P-18-00-17E Engine - Approved Engine Oil Availability
Thu, Jun 8, 2006 Thu, Jun 1, 2006 2006040004A Campaign - Front Axle Carrier Sleeve Update
Thu, Jun 8, 2006 Thu, Jun 1, 2006 P-27-60-61D Auto Trans - Rough 1-2, 3-2, 2-1 Gearshifts
Thu, Jun 8, 2006 Thu, Jun 1, 2006 P-72-12-61A Interior - Rear Door Window Blind Hook is Broken
Thu, Jun 8, 2006 Thu, Jun 1, 2006 T-18-00-26C Engine - Approved Engine Oil Availability
Thu, Jun 8, 2006 Thu, Jun 1, 2006 T-27-60-62C Auto Trans - Rough 1-2, 3-2, 2-1 Gearshifts
Thu, Jun 8, 2006 Thu, Jun 1, 2006 T-63-50-09 Body - Fuel Filler Flap Is Loose
Mon, Jun 19, 2006 Tue, Jun 6, 2006 T-88-80-51 Body - Windshield Water Deflector Protrudes Upwards
Mon, Jun 19, 2006 Thu, Jun 8, 2006 P-07-61-46E Engine Controls - MIL ON and or DTC P201A and or B Set
Mon, Jun 19, 2006 Thu, Jun 8, 2006 P-72-12-67 Body - Rear Door Roller Sun Blind Won't Retract
Mon, Jun 19, 2006 Thu, Jun 8, 2006 T-32-20-39 Suspension - Rear End Creaking and or Grunting Noise On Bumps
Mon, Jun 19, 2006 Fri, Jun 9, 2006 2006040002A Recall - Starter Wiring Harness Inspection and or Replacement
Wed, Jun 28, 2006 Thu, Jun 1, 2006 2006040007 Campaign - Spare Tire Inspection and or Replacement
Wed, Jun 28, 2006 Wed, Jun 14, 2006 2005060008D Campaign - Reprogram Battery Control Module
Thu, Jun 29, 2006 Tue, Jun 13, 2006 P-88-70-48 Lighting - Moisture In Turn Signals in The Mirrors
Thu, Jun 29, 2006 Tue, Jun 13, 2006 T-88-70-49 Lighting - Moisture In Turn Signals in The Mirrors
Thu, Jun 29, 2006 Wed, Jun 14, 2006 T-72-10-65 Interior - Door Trim Panel Creaking Noise
Thu, Jun 29, 2006 Thu, Jun 15, 2006 P-72-10-64 Body - Front Window Creaking Noise When Operating
Thu, Jun 29, 2006 Thu, Jun 15, 2006 P-82-85-507 Audio System - Can't Get Satellite Stations Above 184
Thu, Jun 29, 2006 Thu, Jun 15, 2006 T-88-20-47 Parktronic(R) System - Activates By Itself
Thu, Jun 29, 2006 Wed, Jun 21, 2006 P-07-00-57C Engine Controls - MIL ON and or DTC P1089 Stored
Thu, Jun 29, 2006 Wed, Jun 21, 2006 T-07-00-58C Engine Controls - MIL ON and or DTC P1089 Stored
Thu, Jun 29, 2006 Fri, Jun 23, 2006 P-07-61-46G Engine and or Controls - MIL ON and or Rough Idle and or Fault Code P201A and or B
Thu, Jun 29, 2006 Fri, Jun 23, 2006 T-91-10-113 Interior - Various Noises From The Front Seats
Wed, Jul 19, 2006 Fri, Jun 30, 2006 T-46-10-39 Interior - Chrome Peeling Off Steering Wheel Spokes
Wed, Jul 19, 2006 Fri, Jun 30, 2006 T-46-20-31A Steering - Squealing and or Squeaking Noises When Turning
Thu, Jul 20, 2006 Tue, Jun 6, 2006 P-63-20-06B Body - B-Pillar Cracking and or Tearing Noises
Thu, Jul 20, 2006 Sat, Jul 1, 2006 P-88-50-52 Body - Trunk Lid Valet Lock Retrofitting
Thu, Jul 20, 2006 Thu, Jul 6, 2006 P-18-40-29B Engine - Oil Leaks From The Oil Level Sensor
Thu, Jul 20, 2006 Thu, Jul 6, 2006 P-42-45-74 Electrical - ESP, ABS & BAS 'Defective' Message and or DTC's
Mon, Jul 24, 2006 Sat, Jul 1, 2006 2006060002 Campaign - Inspect and or Replace Air Suspension Compressor
Mon, Jul 24, 2006 Wed, Jul 12, 2006 2006020008B Campaign - Potential Auto Trans Pilot Bushing Leakage
Mon, Jul 24, 2006 Wed, Jul 12, 2006 2006040004B Campaign - Front Axle Carrier Rear Sleeve Cleaning
Mon, Jul 24, 2006 Thu, Jul 13, 2006 T-91-10-113 Interior - Front Seat Noises
Mon, Jul 24, 2006 Fri, Jul 14, 2006 P-27-60-61E Auto Trans - Harsh 1-2, 3-2 and 2-1 Shifts
Mon, Jul 24, 2006 Fri, Jul 14, 2006 T-27-60-62D Auto Trans - Harsh 1-2, 3-2 and 2-1 Shifts
Fri, Jul 28, 2006 Thu, Apr 20, 2006 T-54-30-136D Instruments - SCN Coding for Components R & R
Fri, Jul 28, 2006 Fri, Jul 14, 2006 P-82-62-410B Audio System - No Audio and or No Stations Stored
Fri, Jul 28, 2006 Wed, Jul 19, 2006 P-46-20-33A Steering - Squealing Noises When Turning
Fri, Jul 28, 2006 Wed, Jul 19, 2006 P-77-20-27B Body - Panorama Sliding Roof Noises When Driving
Fri, Jul 28, 2006 Wed, Jul 19, 2006 T-82-60-508 Entertainment System - No Audio From iPod(R)
Fri, Jul 28, 2006 Thu, Jul 20, 2006 2006040002B Recall - Potential Starter Wiring Harness Damage
Fri, Jul 28, 2006 Fri, Jul 21, 2006 P-27-60-77 Auto Trans Controls - Harsh 1-2 or 2-1 Shifts
Fri, Jul 28, 2006 Fri, Jul 21, 2006 P-46-00-44 Steering - Pentosin CHF 11S(R) Power Steering Fluid
Fri, Jul 28, 2006 Fri, Jul 21, 2006 P-54-21-175 Lighting - Tail and or License Plate Lamps Always ON
Fri, Jul 28, 2006 Fri, Jul 21, 2006 T-46-00-45 Steering - Power Steering Fluid Requirements
Mon, Aug 7, 2006 Fri, Jul 28, 2006 2006020008C Campaign - Possible Auto Trans Pilot Bushing Leakage
Mon, Aug 7, 2006 Fri, Jul 28, 2006 2006040004C Campaign - Clean Front Axle Carrier Sleeve and or Replace Bolts
Mon, Aug 7, 2006 Fri, Jul 28, 2006 2006070002 Campaign - Luggage Compartment Stop Plug
Thu, Sep 7, 2006 Tue, Aug 1, 2006 2006060005 Campaign - Exhaust System Shim Plate Installation
Thu, Sep 7, 2006 Tue, Aug 1, 2006 2006080001 Campaign - Navigation System Software Update
Thu, Sep 7, 2006 Tue, Aug 1, 2006 2006080003 Campaign - COMAND(R) and or Navigation Software Update
Thu, Sep 7, 2006 Tue, Aug 1, 2006 2006080006 Campaign - Fuel Tank Vent Grommet Modification
Thu, Sep 7, 2006 Tue, Aug 1, 2006 2006080007 Campaign - Rear Inner Fender Liner Modification
Thu, Sep 7, 2006 Tue, Aug 1, 2006 2006080008 Campaign - Trunk Floor Paneling Modification
Thu, Sep 7, 2006 Tue, Aug 1, 2006 P-82-70-513 Cell Phone - Installation Instructions
Thu, Sep 7, 2006 Tue, Aug 1, 2006 P-82-70-514 Cell Phone - Installation Instructions
Thu, Sep 7, 2006 Tue, Aug 1, 2006 P-82-70-515 Cell Phone - Installation Instructions
Thu, Sep 7, 2006 Tue, Aug 1, 2006 P-82-70-481B Cell Phone - Installation Instructions
Thu, Sep 7, 2006 Tue, Aug 15, 2006 P-27-60-74A Auto Trans - Noises When Using 'Direct Select' Mode (Normal)
Thu, Sep 7, 2006 Tue, Aug 15, 2006 P-54-18-174 Electrical - Various Systems Inoperative
Thu, Sep 7, 2006 Wed, Aug 16, 2006 P-33-25-19 Suspension - Front Suspension Creaking Noise
Thu, Sep 7, 2006 Fri, Aug 18, 2006 P-54-10-176 Electrical - Battery Charging During Repair Work
Thu, Sep 7, 2006 Mon, Aug 21, 2006 P-18-00-31A Instrument - False 'Check Oil Level' Message
Thu, Sep 7, 2006 Mon, Aug 21, 2006 P-42-45-72A ESP and or BAS and or ABS - 'Visit Workshop' Message and or Codes Set
Thu, Sep 7, 2006 Tue, Aug 22, 2006 P-72-10-62 Body - Door Seals Come Loose
Thu, Sep 7, 2006 Tue, Aug 22, 2006 P-54-21-175A Electrical - Tail and or License Lamps ON and or Central Locking Inop.
Fri, Sep 8, 2006 Tue, Aug 1, 2006 S-67-00-20 Body - Laminated Glass Chip and or Crack Repair Information
Fri, Sep 8, 2006 Tue, Aug 1, 2006 P-82-70-516 Cell Phone - Installation Instructions
Fri, Sep 8, 2006 Wed, Aug 9, 2006 P-91-10-112 Interior - Noises From The Front Seats
Fri, Sep 8, 2006 Tue, Aug 15, 2006 P-83-00-79 Air Conditioning - Right Footwell Air Door Actuator Replacement
Fri, Sep 8, 2006 Tue, Aug 15, 2006 P-94-20-05B Interior - Rancid Butter and or Acidic or Putty Like Odors
Fri, Sep 8, 2006 Tue, Aug 15, 2006 T-27-60-55B Auto Trans - Noises When Using 'Direct Select' Mode (Normal)
Fri, Sep 8, 2006 Tue, Aug 15, 2006 P-83-00-78 Air Conditioning - Clicking Noise From The Dash Area
Fri, Sep 8, 2006 Mon, Aug 21, 2006 T-72-00-66 Body - Corrosion On Door Chrome Door Trim
Fri, Sep 8, 2006 Mon, Aug 21, 2006 T-18-00-32A Instruments - False 'Check Oil Level' Message
Fri, Sep 8, 2006 Tue, Aug 29, 2006 T-67-39-21 Body - Rear Window Express Feature Inoperative
Fri, Sep 8, 2006 Tue, Aug 29, 2006 T-91-30-103A Interior - Front Seat Heaters Inoperative
Fri, Sep 8, 2006 Wed, Aug 30, 2006 P-27-20-78 Auto Trans - Jolt At Cruise With Converter Clutch Applied
Fri, Sep 8, 2006 Wed, Aug 30, 2006 P-27-60-80 Engine, Auto Trans Controls - DTC 061B After Reprogramming
Fri, Sep 8, 2006 Wed, Aug 30, 2006 P-77-37-42 Body - Convertible Gets Stuck When Opening
Fri, Sep 8, 2006 Wed, Aug 30, 2006 P-80-20-41 Body - Fuel Filler Flap Cannot Be Opened
Fri, Sep 8, 2006 Wed, Aug 30, 2006 T-27-60-81 Engine, Auto Trans Controls - DTC 061B After Reprogramming
Fri, Sep 8, 2006 Wed, Aug 30, 2006 P-82-85-264 Navigation System - DVD Not Recognized
Fri, Sep 8, 2006 Wed, Aug 30, 2006 T-83-10-80 Air Conditioning - Water Leaks To The Interior
Thu, Sep 14, 2006 Fri, Sep 1, 2006 2006080005 Recall - Tail Lamp Replacement
Thu, Sep 14, 2006 Fri, Sep 1, 2006 P-88-50-54 Body - Trunk Lid Lock Valet Key Retrofitting
Thu, Sep 14, 2006 Fri, Sep 1, 2006 P-88-50-53 Body - Trunk Lid Lock Valet Key Retrofitting
Mon, Oct 9, 2006 Wed, Aug 30, 2006 P-46-20-46 Steering - Play and or Movement Explanation
Mon, Oct 9, 2006 Fri, Sep 1, 2006 2006090001 Campaign - Sluggish Auto Trans Shifting
Mon, Oct 9, 2006 Tue, Sep 12, 2006 P-47-10-30B Diesel Fuel System - Incorrect Type Of Fuel Filled
Mon, Oct 9, 2006 Tue, Sep 12, 2006 P-72-12-61B Interior - Rear Door Window Blind Handle Broken
Mon, Oct 9, 2006 Tue, Sep 12, 2006 P-80-57-38A Memory Systems - Seat Moves To Incorrect Position
Mon, Oct 9, 2006 Fri, Sep 15, 2006 P-72-20-70 Body - Tailgate Creaking Noise On Rough Roads
Mon, Oct 9, 2006 Wed, Sep 20, 2006 P-68-10-42A Interior - Glove Compartment Door Noisy
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-77-37-42A Body - Convertible Gets Stuck Upon Opening
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-77-37-46 Body - Convertible Top Opens and or Closes Slowly and or Inoperative
Mon, Oct 9, 2006 Fri, Sep 22, 2006 2006080005A Recall - Replacement of Tail Lamps
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-46-25-47 Steering - Howling Noise at Idle With Air Conditioning ON
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-77-20-43 Body - Sliding and or Pop-Up Roof Denormalizes
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-77-20-44 Body - Sliding and or Pop-Up Roof Loses Normalization
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-77-33-45 Body - Vario Roof(R) Cracking Noises During Operation
Mon, Oct 9, 2006 Fri, Sep 22, 2006 P-77-33-47 Body - Water Enters Trunk With Vario Roof(R) Open
Tue, Oct 10, 2006 Wed, Aug 30, 2006 P-82-85-524 Navigation System - DVD Not Recognized After Module R&R
Tue, Oct 10, 2006 Fri, Sep 1, 2006 P-82-70-415A Cell Phone - Installing Voice Control System
Tue, Oct 10, 2006 Wed, Sep 13, 2006 P-91-10-116 Interior - Front Seat Backrest Hard to Fold Forward
Tue, Oct 10, 2006 Wed, Sep 13, 2006 P-91-40-115 Restraints - Poor Rear Seat Belt Fit and or Head Restraint Inop
Tue, Oct 10, 2006 Wed, Sep 13, 2006 S-68-00-54 Restraints - Poor Rear Seat Belt Fit and or Head Restraint Inop
Tue, Oct 10, 2006 Wed, Sep 20, 2006 P-83-25-76A Air Conditioning - Blower Motor Stops Running and or DTC 9460 Set
Fri, Oct 20, 2006 Fri, Sep 1, 2006 2006080004 Recall - Instrument Cluster Illumination
Fri, Oct 20, 2006 Fri, Sep 1, 2006 2006090002 Campaign - Seat Control Unit Software
Fri, Oct 20, 2006 Fri, Sep 1, 2006 2006090003 Campaign - Roof Rack Mount Replacement
Fri, Oct 20, 2006 Fri, Sep 1, 2006 2006090004 Campaign - Air Conditioning Service Valve Replacement
Fri, Oct 20, 2006 Tue, Sep 26, 2006 P-46-10-51 Steering - Column In and or Out Function Inoperative
Fri, Oct 20, 2006 Tue, Sep 26, 2006 P-82-10-258C Lighting - Front Turn Signals are Inoperative
Fri, Oct 20, 2006 Tue, Sep 26, 2006 P-82-85-529 COMAND(R) System - Shuts Down and or Codes D014 and or D015
Fri, Oct 20, 2006 Wed, Sep 27, 2006 P-82-62-226C Audio System - Locks Up and or CD Player Information Errors
Fri, Oct 20, 2006 Wed, Sep 27, 2006 P-54-30-177 Instruments - 'Set Cruise Control' Message Not Displayed
Fri, Oct 20, 2006 Wed, Sep 27, 2006 P-82-20-527 Electrical - Overhead Console Functions Inoperative
Fri, Oct 20, 2006 Wed, Sep 27, 2006 P-82-60-457B Entertainment System - iPod(R) Interface Errors
Fri, Oct 20, 2006 Fri, Sep 29, 2006 P-82-85-512A COMAND and or Telematics(R) Systems - Software Upgrade
Fri, Oct 20, 2006 Mon, Oct 2, 2006 P-07-61-46H Engine - MIL ON and or Idles Rough and or Fault Code P201A and or B
Fri, Oct 20, 2006 Mon, Oct 2, 2006 P-68-20-57 Interior - Ashtray and or Storage Compartment Rubbing Noise
Fri, Oct 20, 2006 Mon, Oct 2, 2006 P-68-20-62 Interior - Front Ashtray Rubbing Noises
Fri, Oct 20, 2006 Wed, Oct 11, 2006 P-32-50-42 Suspension - Vehicle Lowers On One Side or Corner
Fri, Oct 20, 2006 Wed, Oct 11, 2006 P-68-10-59 Interior - Rubbing and or Rattling From Glove Compartment Lid
Fri, Oct 20, 2006 Wed, Oct 11, 2006 P-68-20-63 Interior - Center Console Rattling Noises
Fri, Oct 20, 2006 Wed, Oct 11, 2006 P-72-30-74 Body - Squeaking Noise From Doors When Closing
Fri, Oct 20, 2006 Thu, Oct 12, 2006 P-47-30-42 Suspension - Pulsating Noise From The Purge Valve
Fri, Oct 20, 2006 Thu, Oct 12, 2006 P-82-62-537 Audio System - Front Speaker Whirrs and or Clatters and or Distorted
Mon, Oct 23, 2006 Tue, Sep 26, 2006 T-82-85-245A Audio System - Volume Button Sticking and or Binding
Mon, Oct 23, 2006 Wed, Sep 27, 2006 P-82-85-530 Navigation System - CD #4 Not Recognized
Mon, Oct 23, 2006 Wed, Sep 27, 2006 T-82-60-456B Entertainment System - iPod(R) Interface Errors
Mon, Oct 23, 2006 Wed, Sep 27, 2006 T-82-85-531 Navigation System - CD #4 Not Recognized
Mon, Oct 23, 2006 Mon, Oct 2, 2006 T-83-10-80A Air Conditioning - Water Leaks Into The Interior
Mon, Oct 23, 2006 Mon, Oct 2, 2006 T-91-29-118 Restraints - Passenger Seat Weight Sensor Inoperative
Mon, Oct 23, 2006 Mon, Oct 2, 2006 T-91-60-122 Restraints - SRS Lamp ON and or Codes 90C6 and or 90D6 and or 90E6 & 90F6
Mon, Oct 23, 2006 Mon, Oct 2, 2006 P-91-12-119 Interior - Electric Rear Seat Adjustment Inoperative
Mon, Oct 23, 2006 Mon, Oct 2, 2006 P-91-29-117 Restraints - Passenger Seat Weight Sensor Inoperative
Mon, Oct 23, 2006 Mon, Oct 2, 2006 T-82-60-192C Audio System - Volume Fluctuates Unexpectedly
Mon, Oct 23, 2006 Wed, Oct 4, 2006 T-91-60-93D Restraints - SRS Lamp ON and or DTC's 9200 or 9210 Set
Mon, Oct 23, 2006 Wed, Oct 11, 2006 P-91-40-130 Restraints - Rear Seat Belt Won't Retract Properly
Mon, Oct 23, 2006 Wed, Oct 11, 2006 T-82-95-523 Keyless Entry - Remote Door Lock Inoperative
Mon, Oct 23, 2006 Wed, Oct 11, 2006 T-91-40-131 Restraints - Seat Belts Won't Retract Properly
Mon, Oct 23, 2006 Thu, Oct 12, 2006 T-91-40-129 Restraints - 'PRE-SAFE Not Available' Message Displayed
Mon, Oct 23, 2006 Thu, Oct 26, 2006 P-98-10-16 Body - Trunk Lid Paint Peeling
Mon, Oct 23, 2006 Fri, Oct 27, 2006 T-47-00-41 Instruments - Fuel Gauge Drops To 'EMPTY'
Thu, Oct 26, 2006 Sun, Oct 1, 2006 P-82-95-518 Digital Tele Aid - Control Module Retrofitting
Thu, Oct 26, 2006 Sun, Oct 1, 2006 P-82-95-519 Digital Tele Aid - Control Module Retrofitting
Thu, Oct 26, 2006 Sun, Oct 1, 2006 P-82-95-520 Digital Tele Aid - Control Module Retrofitting
Thu, Oct 26, 2006 Sun, Oct 1, 2006 P-82-95-521 Digital Tele Aid - Control Module Retrofitting
Thu, Oct 26, 2006 Sun, Oct 1, 2006 P-82-95-522 Digital Tele Aid - Control Module Retrofitting
Thu, Oct 26, 2006 Sun, Oct 1, 2006 T-82-95-517 Digital Tele Aid - Control Module Retrofitting
Thu, Oct 26, 2006 Fri, Oct 13, 2006 T-72-00-73 Locks - Door Lock Knobs Jump Up and Down
Thu, Oct 26, 2006 Fri, Oct 13, 2006 T-83-00-82 Air Conditioning - Too Cold and or Too Hot and or DTC B1008 Set
Thu, Oct 26, 2006 Mon, Oct 16, 2006 P-82-85-507A Satellite Radio - Limited Channel 184 or Lower
Thu, Oct 26, 2006 Mon, Oct 16, 2006 P-91-10-125 Memory Systems - Easy Entry and or Exit Feature Inoperative
Thu, Oct 26, 2006 Mon, Oct 16, 2006 T-91-10-126 Memory Systems - Easy Entry and or Exit Feature Inoperative
Thu, Oct 26, 2006 Wed, Oct 18, 2006 P-91-50-128 Interior - Rear Head Restraint Lowering Function Inop.
Thu, Oct 26, 2006 Thu, Oct 19, 2006 P-43-10-01 Brakes - Poor Power Assist On Cold Start Up
Mon, Nov 6, 2006 Thu, Oct 19, 2006 2006100003 Campaign - Starter Wiring Harness Routing
Mon, Nov 6, 2006 Thu, Oct 19, 2006 2006100001 Campaign - Rear Axle Alignment Inspection
Mon, Nov 6, 2006 Thu, Oct 19, 2006 2006100002 Campaign - Rear Wheel Carrier Replacement
Mon, Nov 6, 2006 Thu, Oct 19, 2006 2006100005 Campaign - Trunk Lid handle Strip Replacement
Mon, Nov 6, 2006 Thu, Oct 19, 2006 2006070003 Campaign - Glow Plug Replacement
Mon, Nov 6, 2006 Tue, Oct 24, 2006 S-27-19-82 Auto Trans - Electrohydraulic Control Unit Part Numbers
Mon, Nov 6, 2006 Tue, Oct 24, 2006 S-27-56-83 Auto Trans - Filter Part Number and or Replacement Information
Mon, Nov 6, 2006 Fri, Oct 27, 2006 T-27-60-68D Auto Trans - Uncomfortable 2-1 Downshift When Coasting and or Braking
Mon, Nov 6, 2006 Fri, Oct 27, 2006 2006060005A Campaign - Exhaust System Modification
Tue, Nov 14, 2006 Tue, Oct 3, 2006 P-27-00-87 Auto Trans - 1-2 Shift Flare When Cold (Under Investigation)
Tue, Nov 14, 2006 Tue, Oct 31, 2006 T-46-10-48 Steering Wheel - Multi-Function Buttons Inoperative
Tue, Nov 14, 2006 Fri, Nov 3, 2006 P-00-00-80D Engine - Increased Oil Consumption
Tue, Nov 14, 2006 Fri, Nov 3, 2006 2006080004A Recall - Instrument Cluster Inspection and or Replacing
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-520A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-521A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-522A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Wed, Nov 1, 2006 2006110001 Campaign - Power Steering Hose Routing
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-509A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-517A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-518A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Wed, Nov 1, 2006 P-82-95-519A Digital Tele Aid(R) - Control Module Retrofit
Wed, Nov 22, 2006 Mon, Nov 6, 2006 P-09-20-26 Engine - MIL ON and or Shakes at Idle and or Codes 0745 and or 0749
Wed, Nov 22, 2006 Mon, Nov 6, 2006 T-09-20-27 Engine - Shakes at Idle and or MIL ON and or Codes 0745 and or 0749
Wed, Nov 22, 2006 Tue, Nov 7, 2006 P-32-22-43 Traction Control - Acceleration Sensor Elimination
Wed, Nov 22, 2006 Tue, Nov 7, 2006 P-82-30-528 Body - Water Inside Tailgate and or Electrical Malfunctions
Wed, Nov 22, 2006 Tue, Nov 7, 2006 P-91-25-120 Interior - Noise From Seat Bladder
Wed, Nov 22, 2006 Tue, Nov 7, 2006 P-91-40-127 Restraints - Noise From The Front Seat Belts
Wed, Nov 22, 2006 Tue, Nov 7, 2006 T-27-60-68E Auto Trans - Uncomfortable 2-1 Coastdown Downshift
Wed, Nov 22, 2006 Tue, Nov 7, 2006 T-32-22-44 Traction Control - Acceleration Sensor Elimination
Wed, Nov 22, 2006 Tue, Nov 7, 2006 T-72-10-72 Body - Wind Noise From Upper Rear of Front Door
Wed, Nov 22, 2006 Mon, Nov 13, 2006 P-07-00-57D Engine Controls - MIL ON and or DTC P1089 Stored in Memory
Wed, Nov 22, 2006 Mon, Nov 13, 2006 P-47-10-40A Fuel System - Tapping Noise From Fuel Tank
Fri, Dec 1, 2006 Wed, Nov 1, 2006 2006110003 Campaign - Tail Lamp Resealing
Fri, Dec 1, 2006 Wed, Nov 15, 2006 P-42-45-61A Electrical - 'ESP Visit Workshop' Message Displayed
Fri, Dec 1, 2006 Wed, Nov 15, 2006 P-72-00-71 Body - Window Creaking Noise During Operation
Fri, Dec 1, 2006 Wed, Nov 22, 2006 2006080005B Recall - Tail and or Stop Lamp Replacement
Fri, Dec 1, 2006 Wed, Nov 22, 2006 2006110005A Campaign - Navigation DVD Update
Fri, Dec 1, 2006 Wed, Nov 22, 2006 P-72-10-63 Body - Left Hand Interior Door Handle Inoperative
Fri, Dec 1, 2006 Wed, Nov 22, 2006 P-82-10-406B Lighting - Brake Lamps Are Inoperative
Fri, Dec 1, 2006 Wed, Nov 22, 2006 P-91-30-121 Air Conditioning - Rear Seat Cooling Fan Grinding and or Rattling Noises
Fri, Dec 1, 2006 Wed, Nov 22, 2006 P-91-60-78D Restraints - SRS Lamp ON and or DTC's 9103 and or 9123 Stored
Fri, Dec 1, 2006 Wed, Nov 22, 2006 P-47-10-43 Diesel Fuel System - Fuel Requirements
Fri, Dec 1, 2006 Wed, Nov 22, 2006 T-47-10-44 Diesel Fuel System - Fuel Requirements
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-26-50-02 Manual Trans - First or Reverse Gear Difficult to Engage
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-27-60-61F Auto Trans - Rough Shift Quality
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-27-60-88 Auto Trans - Fault Codes 2502, 2505, P0894 or P2711
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-46-20-52 Steering - Muffled Knocking Noises
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-54-30-164A Instruments - Dim Multifunction Display
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-54-30-179 Instruments - Menus Not Displayed After Coding
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-68-30-60 Instrument - Noises from Area of Overhead Control Panel
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-68-30-61 Body - Fuel Tank Cover Noise
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-68-50-64 Interior - Electric Sunshade Stops or Hesitates
Mon, Dec 18, 2006 Mon, Nov 27, 2006 T-13-22-02 Engine - Whining and or High Pitch Whistle Noise
Mon, Dec 18, 2006 Mon, Nov 27, 2006 T-27-60-62E Auto Trans - Rough Shift Quality
Mon, Dec 18, 2006 Mon, Nov 27, 2006 P-13-22-01 Engine - Whining and or High Pitch Whistle Noise
Mon, Dec 18, 2006 Tue, Nov 28, 2006 P-15-40-60 Charging System - Returning Alternators & Regulators
Mon, Dec 18, 2006 Tue, Nov 28, 2006 T-15-40-61 Charging System - Returning Alternators & Regulators
Mon, Dec 18, 2006 Wed, Nov 29, 2006 P-68-10-65 Instruments - Noises at the Instrument Cluster
Mon, Dec 18, 2006 Wed, Nov 29, 2006 P-72-10-75 Doors - Difficulty Opening Doors from Outside
Mon, Dec 18, 2006 Wed, Nov 29, 2006 P-82-85-532A Diagnostic Enhancement - MCSII EDAC
Mon, Dec 18, 2006 Wed, Nov 29, 2006 P-91-25-123 Seats - Seat Control Valve Switch Knob Broken
Mon, Dec 18, 2006 Thu, Nov 30, 2006 P-42-10-75 Brakes - Front Axle Brake Squeal
Mon, Dec 18, 2006 Thu, Nov 30, 2006 P-80-20-39 Trunk - Replacing and or Programming Trunk Control Module
Mon, Dec 18, 2006 Fri, Dec 1, 2006 2006110005B Campaign - Install Software for Navigation System
Mon, Dec 18, 2006 Fri, Dec 1, 2006 2006110002 Campaign - Check ECM Software
Mon, Dec 18, 2006 Fri, Dec 1, 2006 2006110004 Campaign - Replace Front Axle Brake Pads
Mon, Dec 18, 2006 Fri, Dec 1, 2006 2006110007 Campaign - Check Routing of Brake Lines
Mon, Dec 18, 2006 Fri, Dec 8, 2006 2006110002A Campaign - Check ECM Software Version
Mon, Dec 18, 2006 Fri, Dec 8, 2006 2006110004A Campaign - Replace Front Axle Brake Pads
Mon, Dec 18, 2006 Mon, Dec 11, 2006 T-18-00-33 Engine - Oil Level Too Low
Mon, Dec 18, 2006 Mon, Dec 11, 2006 T-47-10-44A Fuel System - Diesel Fuel Requirements
Tue, Dec 19, 2006 Mon, Nov 27, 2006 T-32-22-45 Suspension - Cracking, Knocking or Thumping Noises
Tue, Dec 19, 2006 Mon, Nov 27, 2006 T-54-10-178 Instruments - Battery Symbol and Visit Workshop
Tue, Dec 19, 2006 Mon, Nov 27, 2006 T-54-30-180 Instruments - After SCN Coding IC Shows No Menus
Tue, Dec 19, 2006 Mon, Nov 27, 2006 T-27-60-89 Auto Trans - 722.9 - Fault Codes 2502, 2505, P0894 or P2711
Tue, Dec 19, 2006 Wed, Nov 29, 2006 T-88-70-56 Body - Creaking Noise When Mirrors Folded Out
Tue, Dec 19, 2006 Wed, Nov 29, 2006 T-88-79-57 Body - Exterior Mirror Cannot Be Adjusted
Tue, Dec 19, 2006 Wed, Nov 29, 2006 T-91-25-124 Seats - Seat Control Valve Switch Knob Broken
#58
06 C230
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-564 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-565 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-566 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-567 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 S-82-95-541 Digital Tele Aid(R) - Control Module Overview
Fri, Jan 12, 2007 Fri, Dec 1, 2006 S-82-95-543 Digital Tele Aid(R) - Control Module - DAS Procedure
Fri, Jan 12, 2007 Fri, Dec 1, 2006 2006120004 Campaign - Replace Trailer Hitch
Fri, Jan 12, 2007 Fri, Dec 1, 2006 2006120005 Campaign - Install Aux Socket
Fri, Jan 12, 2007 Fri, Dec 1, 2006 2006120006 Campaign - Replace ABC Pressure Line and or Coolant Hose
Fri, Jan 12, 2007 Fri, Dec 1, 2006 2006120008 Recall - Check Accelerator Pedal Nuts
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-535 Digital Tele Aid(R) - Control Module Retrofitting
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-546 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-548 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-549 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-560 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-561 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Fri, Dec 1, 2006 P-82-95-563 Digital Tele Aid(R) - Control Module Retrofit
Fri, Jan 12, 2007 Tue, Dec 12, 2006 T-72-12-69 Body - Stone Chips in Area of Rear Doors
Fri, Jan 12, 2007 Thu, Dec 14, 2006 P-49-10-10A Tools - Catalyst Noise Analysis Tool
Fri, Jan 12, 2007 Sat, Dec 16, 2006 2006110002B Campaign - Check ECM Software Version and Update
Fri, Jan 12, 2007 Thu, Dec 21, 2006 P-07-6165 Engine Controls - MIL On and or DTCs 0338,0342,2090 or 2094
Fri, Jan 12, 2007 Thu, Dec 21, 2006 P-61-45-05A Body - Rear Diffuser Poor Fit
Fri, Jan 12, 2007 Thu, Jan 4, 2007 T-05-20-21 Engine - Sporadic Noise On Warm Start Up
Fri, Jan 12, 2007 Thu, Jan 4, 2007 P-05-20-20 Engine - Sporadic Noise On Warm Start Up
Fri, Jan 12, 2007 Mon, Jan 8, 2007 P-42-10-75A Brakes - Front Brake Squeal On Light Application
Thu, Jan 25, 2007 Mon, Jan 1, 2007 2007010002 Campaign - Front Wheelhouse Drain Clogging
Thu, Jan 25, 2007 Mon, Jan 1, 2007 2007010005 Campaign - Brake Master Cylinder Cover Replacement
Thu, Jan 25, 2007 Fri, Jan 12, 2007 2006100001A Campaign - Rear Wheel Toe Alignment Inspection
Thu, Jan 25, 2007 Fri, Jan 12, 2007 2006100002A Campaign - Rear Brake Caliper Mounting
Thu, Jan 25, 2007 Fri, Jan 12, 2007 2006110002C Campaign - ECM Software Update
Thu, Jan 25, 2007 Fri, Jan 12, 2007 2006120008A Recall - Accelerator Pedal Mounting
Thu, Jan 25, 2007 Fri, Jan 19, 2007 2006020008D Campaign - Auto Trans Pilot Bushing Inspection
Fri, Jan 26, 2007 Tue, Jan 9, 2007 P-32-20-17B Suspension - Front End Rumbling and or Knocking Noises
Fri, Jan 26, 2007 Wed, Jan 10, 2007 T-00-00-81D Engine - Increased Oil Consumption and or Incomplete Break-In
Fri, Jan 26, 2007 Wed, Jan 10, 2007 T-18-00-33A Engine - Oil Level is Too Low
Fri, Jan 26, 2007 Wed, Jan 10, 2007 T-72-20-43C Body - Power Tailgate Closing Assist Intermittently Inop
Fri, Jan 26, 2007 Tue, Jan 16, 2007 P-27-60-88A Auto Trans - Limp Home Mode and or Codes 2502 and or 2505 and or P0894 and or P2711
Fri, Jan 26, 2007 Tue, Jan 16, 2007 P-28-00-07 Drivetrain - 4-Matic Drive(R) System Introduction
Fri, Jan 26, 2007 Tue, Jan 16, 2007 P-43-10-02A Brakes - Squeal and or Whistle When Releasing Brake Pedal
Fri, Jan 26, 2007 Tue, Jan 16, 2007 T-27-60-89A Auto Trans - Limp Home Mode and or DTC's 2502 and or 2505 and or P0894 and or P2711
Fri, Jan 26, 2007 Thu, Jan 18, 2007 P-18-00-31B Instruments - False Low Oil Level Message
Fri, Jan 26, 2007 Thu, Jan 18, 2007 P-27-19-91 Auto Trans Controls - 'M' Mode Not Available
Fri, Jan 26, 2007 Thu, Jan 18, 2007 P-46-40-53 Steering - Cracks and or Creaks From Steering Rack Area
Fri, Jan 26, 2007 Thu, Jan 18, 2007 P-54-21-155A Electrical - 'Battery' Displayed On Cluster and or Code 9000
Fri, Jan 26, 2007 Thu, Jan 18, 2007 P-61-045-05B Body - Poor Rear Diffuser to Rear Bumper Fit
Fri, Jan 26, 2007 Thu, Jan 18, 2007 P-77-30-49 Body - Hard Top to A-Pillar Seal Collapsed
Fri, Jan 26, 2007 Thu, Jan 18, 2007 T-27-00-90 Drivetrain Controls - Low Range Starting Torque Too Low
#60
Not sure if any of you are aware of this, but it maybe possible for you to gain access to the Technical Service Bulletins on chiltonlibrary.com by using your local library. I think it's a service my library pays for....
Via my library's web site I can log on from my home using my library card number and search the TSB's and repair information for any car. it's great, my advisor was shocked when I brought a print up of a TSB for the problem I was having.
Check it out! it's good reading!
#61
03 c230
2003 C230
General Recalls
TSB Number & Issue Date TSB Title
2003030009 APR 04 Engine - Air Intake Duct Not Connected to Cover Cap
Service Bulletins
P-07_61-46 MAR 05 Engine Controls - MIL ON/DTC P201A/B/Rough Running
P-27_55-50A FEB 05 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
P-82_10-398A JAN 05 Lighting - License Plate Bulbs Burned Out
P-54_21-133 JAN 05 Lighting - Trunk/Cargo Light Inoperative
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-54_21-121 JAN 05 Lighting - Brake/Park Lamps Flicker With Engine ON
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_21-124 DEC 04 Lighting - Headlamps/IP Lamps Flicker
P-54_21-126 DEC 04 Power Locks - Central Locking System Inoperative
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-54_21-119 OCT 04 Lighting - Tail/Brake Lamps ON Continuously
P-05_20-13 OCT 04 Engine - Rattling Noise on Start-Up
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-72_00-33 SEP 04 Body - Front/Rear Window Knocking Noise When Operated
P-82_10-376 SEP 04 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
P-82_62-391 SEP 04 Audio System - Comes ON at Maximum Volume
P-09_00-18 SEP 04 Fuel System - MIL ON/DTC's P2029/P0172/P201C Set
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-82_20-370 SEP 04 Lighting - Dome Lamp Won't Come On
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-42_45-23F AUG 04 Traction Control/ABS - Codes C1140/C1145 Set
P-68_20-29 AUG 04 Interior - Console/Armrest Lid Rubbing Noise
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-65B JUL 04 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
P-77_20-26 JUL 04 Body - Sliding Roof Excess Lift Control Feature
P-01_40-14A JUN 04 Engine - Oil Leak Through Cylinder Head Bolt Thread
P-68_50-24 JUN 04 Interior - Sunblind Chafe Guard/Loose
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-83_40-71 APR 04 Climate Control - Heating and Cooling Set-Points
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-33_10-11 APR 04 Suspension - Rumbling Noise Driving Over Rough Roads
P-82_60-303 MAR 04 Audio System - Satellite Radio Installation
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_00-228B FEB 04 Audio System - Mutes Randomly
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-82_30-279B NOV 03 Wipers/Washers- Poor Wiper Performance
P-07_61-037A NOV 03 Engine Controls - Cold Start Idle Fluctuation/No DTC's
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-82_70-284 AUG 03 Cell Phone - Voice Activated Cell Phone Installation
My car falls under hear but how do I know if mine qualifies for any of these services?
#65
noobie question but can i take this anytime this year for them to fix the problem? i have a 2004 c230k sport sedan. i love this forum and it gives me a lot of important info i need but i'm still a noob at some terms. sorry
#66
passenger seat+window+lock+mirror problems
my MB extended warranty is just expired; and the passenger side window, power seat, mirror and central lock are not functioning. The central lock and power window are working fine on the other 3 doors. The fuses are o.k. I tried to swap the CAN unit under the seat but won't help. what would it be. Please help. Thanks
#68
2003 C230 Coupe
I was able to gain access to TSBs on My MB (Any model for that matter) through my libray online access. I just had to enter my library card number and then search the Auto Repair Reference Center area.
That's great service. Try that out. I will be busy now for a while digging through some potential misterious stuff I haven't noticed and some I have on my new 2003 C230 Coupe.
#69
HI everyone! I have a problem with my MB c240 and i need your help please , the thing is that my car won't lock/unlock doors with remote control from a long distance for example more than 5 feet also the alarm siren is not working except the flash light when the faith alarm starts the problem happened yesterday when i was fixing some lamps on rear side of the back, does anyone can help me with this please? I really appreciate that...
#70
2003 C230 Coupe
This thread is for TSBs and how to access them. I doubt many people will find your entry.
Unusual though how the work on the lights would have any connection with the remote. But since you indicate it works but only when you are very near to the car, I would say the cheapest thing to do is to replace the 2 batteries on the remote or to use the other spare remote , if you have 2 "keys" and see if that helps.
#71
Super Moderator
Had our C230’s upper guide pulley replaced under Service Campaign #2008070002 at no charge.
It’s applicable to virtually all ’06 and ’07’s fitted with the M272 or M273.
#72
Super Moderator
#73
Super Moderator
I wish. It’s my mother’s. Alabaster white and absolutely flawless.
She and dad have had it almost two years to accumulate the 13,000 miles for its second service A.
If at all possible to swap in the C32’s drivetrain and underpinnings before its FJ lease was up, I’d buy it. :D
#74
1 Post
2003 C240 automatic
Hey all, I have a c240 built in 2002 (2003 model). And was trying to find out if I have the Valeo (car destroying radiator) or the Behr radiator, but can't find a sticker on it and the TSB pictures I find unuseable...
The picture included is my radiator on the pax side of the car..
http://tinypic.com/view.php?pic=hs1a21&s=3
#75
C200K sport coupe
P-88_30-36 OCT 04
Where can I find this bulletin descripton and cause please.
I do have a tunnel scraping noise which does sound like a cowling clip or 2 have come adrift.
Thanks in anticipation.
Tim
Tim
