Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-12-2006, 05:42 PM   #1
Drives: 2010 C63 AMG
How do you install a boost gauge for the M271 Engine
I searched some forums and found some good info but it seems to be for the M111 engine and the SLK32 car. How much differnt is it for the M271 engine? Is it as easy as to tap into a tee vacuum line?
To remove this ad, register today or login if you already are registered!
__________________
2010 C63 AMG Black
pugguy2001 is offline   Reply With Quote
Old 07-12-2006, 06:41 PM   #2
Buellwinkle's Avatar
Just T into a vacuum line near the throttle body.
__________________
2008 Audio A4 Cabriolet Quattro
www.Buellwinkle.com
www.NetworkCameraCritic.com
Buellwinkle is offline   Reply With Quote
Old 07-12-2006, 08:01 PM   #3
infected's Avatar
Drives: CL203
I believe there was a thread a while back where it was a step by step write up on how to tap into the Vacuum line. He used an Autometer guage that only went up to 15psi and it was mounted on his A-pillar. Try searching it up.
__________________
Link to Build Thread
http://mbworld.org/forums/c-class-w2...eds-coupe.html
infected is offline   Reply With Quote
Old 07-12-2006, 08:47 PM   #4
Quote:
before or after the throtle body. do i have to remove the engine cover
__________________
2010 C63 AMG Black
Old 07-12-2006, 08:50 PM   #5
rlee02135's Avatar
Drives: 2004 C32 ///AMG
someone should write up a DIY on this.
__________________
evosport•POWERCHIP•GREENTOYOKWSTOPTECH•MAGNECOR
DENSO IridiumEUROteck•JL AUDIO•MP Design•HRE•LET Motorsports
rlee02135 is offline   Reply With Quote
Old 07-12-2006, 09:42 PM   #6
Quote:
I second that.
__________________
2010 C63 AMG Black
Old 07-13-2006, 07:36 PM   #7
white_w203's Avatar
Drives: is SOLD
Send a message via AIM to white_w203 Send a message via Yahoo to white_w203
i have been planning to do this for some time now. this actually brought it back to my attention
__________________
l '05 Kleemann C20K | 6-Speed l Kleemann M271 Boost Kit l Kleemann Logo Package l CF Front Lip l DTM Kreuz 10 l Toyo T1R | Brembo BBK l Tein Coilovers | K&N Air Filter l Painted Engine Covers l Bi-Xenons | Euro Impact Strips l Pioneer AVIC-N1 l Soundstream PCA1000D l JL Audio W6v2 l
white_w203 is offline   Reply With Quote
Old 07-13-2006, 07:56 PM   #8
I wrote one awhile back, but it was poted on mbklasse.com which appears to be down for some time now.
levelr123g is offline   Reply With Quote
Old 07-13-2006, 08:39 PM   #9
rlee02135's Avatar
Quote:
no, just got to mbklasse.com/forums
__________________
Old 07-13-2006, 09:31 PM   #10
I know i checked it out, it was very helpfull, but your engine is a m111. Has anybody done this for the M271. I cant find a tee to tie into like the M111 has. Has anyone come up with a pillar with the gauge pods in them for our cars. I've been searching and search but no one has a custom replacement. You think with our cars being supercharged there would have been one out along time ago?
__________________
2010 C63 AMG Black
Old 07-14-2006, 03:27 PM   #11
I realize that I had a different engine, but the hooup will be the same!
Old 07-14-2006, 03:35 PM   #12
infected's Avatar
Drives: CL203
Anyway you can pull the write up back up?
__________________
Old 07-14-2006, 11:38 PM   #13
Drives: 2005 C Wagon (No snickering please!)
A word of caution from someone who has blown a motor by relying on an inexpensive boost gauge. They are not very accurate. They can be as much as 30% away from the true reading. I found that you had to spend around $ 250.00 for an accurate gauge, and pay a test lab about $100. to certify it. That is a little pricey if the gauge is just for show. For show any gauge will be fine, but if you are watching the boost gauge to avoid excessive intake pressure, you really need an accurate gauge.
I had an Audi, and I connected a valve on the dash to the waste gate so I could dial in the power from the c0ckpit. The cheap VDO gauge said I had 4 lbs boost, when I actually had 11. The valves and pistons did not play well together. I had to take a bus home.
Moviela is offline   Reply With Quote
Old 07-14-2006, 11:52 PM   #14
white_w203's Avatar
Drives: is SOLD
whoa....aren't defi gauges around that price?
__________________
Old 08-27-2006, 03:02 AM   #15
Is the throtle body on these cars just after the air intake. Is it somewhere in the red area I circled? If so now I just need to tee into a vacuum line?
__________________
2010 C63 AMG Black
Old 08-27-2006, 07:51 AM   #16
The boost gauge should be tapped before the oneway valve going to the EGR solenoid which is hidden under the head cover
arell is offline   Reply With Quote
Old 08-27-2006, 09:19 AM   #17
Quote:
Where is the head cover? Can you point it out from this picture.
__________________
2010 C63 AMG Black
Old 08-27-2006, 11:32 AM   #18
remove the silver 'Mercedes-Benz' cover. Remove the two bolts below it.
Now you will see the ignition coil packs and a solenoid valve aside. There is a check valve from the solenoid going to the manifold. This is where you will want to 'T' your gauge into.
Old 08-27-2006, 12:06 PM   #19
Is this what you are talking about? Which side do I tee into, the side by the fire wall or the side towards the front of the car?
Once I removed the Mercedes-Benz cover the coil packs are right there. I didnt remove 2 bolts below it?
__________________
2010 C63 AMG Black
Old 08-27-2006, 01:07 PM   #20
yeap that is the solenoid. Further down (not shown in your pic) you will find a check valve. The further end of the check valve (not the end going to this solenoid) is where you Tee off. BTW, blanking off the EGR bleed from the supercharger gave better low end torque. I tried it on the dyno. This I think is due to the engine getting more boost by not allowing some air to the catalytic converter. I have been trying to tune the ECU with Dastek Unichip piggyback system.
Old 08-27-2006, 01:08 PM   #21
BTW, no bolts, my bad!
Old 08-27-2006, 01:46 PM   #22
Hey thanks Arell, so far so good. I can follow what you are saying. I will take another picture further down to locate the check vavle.
Where is this EGR bleed. When you say blank it you me plug the end.
Thanks for great instructions, so far.
__________________
2010 C63 AMG Black
Old 08-27-2006, 02:13 PM   #23
That gold colored actuator where the two lines after the solenoid leads to, above and slightly in front of the header. On the EGR you can see one ~1/2" hose going to the intercooler piping. I inserted an aluminium rod inside that hose to block it off.
Old 08-27-2006, 11:17 PM   #24
Ok I think you are talking about this 1/2 hose. Is there a way to just cap it of where the hose is connected. If I put a rod inside the hose it will block it off and also make it look as if there was no messing around with it? I like that idea better.
Ok next I followed the hoses from the egr selonoid to the right and towards the front and I see there is a tee with one coming from the egr seloniod, one going into the supercharger and one i dont know where it goes. Then on the other side of the supercharger there is a tube coming out of the supercharger but then it hooks into a thin white tube?
So far I think I am still with you. Your insrtuctions are great!
__________________
2010 C63 AMG Black
Old 08-28-2006, 07:30 AM   #25
Yeap I inserted a rod inside so it can't be seen from the outside. BTW, the boost gauge tee off is now clearly marked in the following picture:
Tags
air, boost, c230, coil, dastek, egr, gauge, hose, intake, m271, mercedes, packs, r350, unichip, w124
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
